I've got my code working, but it bugs me that I don't understand some things that are going on under the hood. Can someone give me a line by line description of what the following functions (in bold) are actually doing?
void SoftwareSerial::setTX(uint8_t tx)
// First write, then set output. If we do this the other way around,
// the pin would be output low for a short while before switching to
// output high. Now, it is input with pullup for a short while, which
// is fine. With inverse logic, either order is fine.
digitalWrite(tx, _inverse_logic ? LOW : HIGH);
pinMode(tx, OUTPUT);
** _transmitBitMask = digitalPinToBitMask(tx);**
** uint8_t port = digitalPinToPort(tx);**
** _transmitPortRegister = portOutputRegister(port);**
void SoftwareSerial::setRX(uint8_t rx)
pinMode(rx, INPUT);
if (!_inverse_logic)
digitalWrite(rx, HIGH); // pullup for normal logic!
_receivePin = rx;
** _receiveBitMask = digitalPinToBitMask(rx);**
** uint8_t port = digitalPinToPort(rx);**
** _receivePortRegister = portInputRegister(port);**
Also, is there documentation on the functions and variables in the following lines of code that are given in the SoftwareSerial.h library. In general, I can see what the functions are doing, and I've got a good background in micros, just need some documentation to understand details. Is there anything from Atmel that has more info?
*digitalPinToPCICR(_receivePin) |= _BV(digitalPinToPCICRbit(_receivePin));
// Precalculate the pcint mask register and value, so setRxIntMask
// can be used inside the ISR without costing too much time.
_pcint_maskreg = digitalPinToPCMSK(_receivePin);
_pcint_maskvalue = _BV(digitalPinToPCMSKbit(_receivePin));
