Detect a detachment of an object
Hi everybody,
I have a removable object and I want to know/detect whether this object is detached or attached.
How can I achieve this using arduino?
Thank you.
http://hiteh.us/deep-learning-robot-shows-grasp-of-different-objects/ might give you some ideas.
Thank you. I will use infrared for this finally...
Well you have already made up your mind but a reed switch would have been a nice option as well but then again I don't exactly know what kind of application you are working on.
Thank you waqaszahid.
I want to know when a particular object 1 is attached or detached from another particular object 2. When the object 1 is detached (respectively attached), the state "attached" (respectively "detached") will be available only if object 1 is (respectively isn't) on contact with object 2.
User can go everywhere he want with object 1. Can I achieve this with reed switch too?
well if you read the basic functionality of a read switch, it switches state whenever a magnet is brought near it, say if the controller is connected to object2 with the reed switch installed at the right place then you can have a piece of neodymium magnet attached to object1 and whenever the two are brought close the reed switch should work. I am not sure what type of mechanical assembly you are working with but seriously the you can pretty much use anything that suits your application.
