I want to create a project in which arduino would detect when a human (or anything else) would breath into a sensor. I want it to be even a light breath. It has to be breath (CO2) no other gas. I want it to be accurate therefore no microphone. I found some really expensive co2 sensors on ebay for (50-60) USD. I belive there must be something cheaper to do this simple job. For example, do the alcohol detectors for few bucks detect sober humans breath? If not, what else could I use? I want it to be maximum abou 15 dollars. Thank you.
CO2 detectors are relative expensive, 50-60$ are in fact cheaper ones
Breath also has a lot of water vapour so you could make a detector with a small mirror, a led and a sensor to measure the reflection.
Another option might be using a DHT11 (~10$) to detect humidity and temperature.
Air inhaled has different properties than air exhaled.
The DHT11 is not very good in humidity but good enough to see the difference
