I try to read the status of my washmachine, when switched off, led is off, when on and washing, led is on, when finished, led is flashing.
I got a TSL 250R light-to-voltage sensor, attached to the status-led of my washingmachine. When there is no light on the sensor, voltage is 0V, when there is full light on the sensor, voltage is 5V. When the status-led is on, i measure about 3,8V. Thats enough to make a digital-in HIGH.
I used a script wich counts button presses. Now it counts flashes. I try'd to do a notification after 4 flashes, but when washing starts it has to reset and wait for 4 flashes again so it can notify its finished again.
This is how the status-led will act during the use.
IDLE Flashing
WASHING Full on
FINISHED -> IDLE Flashing
POWER OFF Off
State change detection (edge detection)
Often, you don't need to know the state of a digital input all the time,
but you just need to know when the input changes from one state to another.
For example, you want to know when a button goes from OFF to ON. This is called
state change detection, or edge detection.
This example shows how to detect when a button or button changes from off to on
and on to off.
The circuit:
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* LED attached from pin 13 to ground (or use the built-in LED on
most Arduino boards)
created 27 Sep 2005
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int washPin = A1; // the pin that the pushbutton is attached to
const int ledPin = 9; // the pin that the LED is attached to
// Variables will change:
int flashCounter = 0; // counter for the number of button presses
int flashState = 0; // current state of the button
int lastFlashState = 0; // previous state of the button
int flashing = 0;
int notifySend = 0;
// initialize the button pin as a input:
pinMode(washPin, INPUT);
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
readStatus();
if(flashing == 1 && notifySend == 0) {
Serial.println("4 flashes, send notification");
notifySend = 1;
if (led full) { //<----------------- Help?
notifySend = 0;
void readStatus() {
// read the pushbutton input pin:
flashState = digitalRead(washPin);
if (flashCounter == 4) {
flashing = 1;
// compare the buttonState to its previous state
if (flashState != lastFlashState) {
// if the state has changed, increment the counter
if (flashState == HIGH) {
// if the current state is HIGH then the button
// wend from off to on:
flashCounter++;
Serial.println("on");
Serial.print("Flashes: ");
Serial.println(flashCounter);
else {
// if the current state is LOW then the button
// wend from on to off:
Serial.println("off");
// save the current state as the last state,
//for next time through the loop
lastFlashState = flashState;
