Hello,
A few days ago I posted another question on this forum and I got the following bit of code in response.
#include <Bounce2.h>
const byte buttonPins[] = {2, 3, 4, 5, 6, 7, 8, 9}; //now you can select any pin in any order
bool state = false;
Bounce buttons[sizeof(buttonPins)];
void setup () {
for (byte i = 0; i < sizeof(buttonPins); i++) {
buttons[i].attach(buttonPins[i], INPUT_PULLUP);
Serial.println("start");
updateButtons();
Serial.println(state); // prints a 1 or 0 so I can see if the value switched
void updateButtons(){
buttons[i].update();
//if a button is pressed but did not became pressed we skip checking for buttons becomming pressed
if(!buttons[i].read() && !buttons[i].fell()){
return;
//otherwise we check for a button becomming pressed
if (buttons[i].fell()) {
state = !state;
return;
I did not need this particular bit of code at the time as I did not care if a button was pressed while another button is pressed.
However I thought I could modify this bit of code to detect when a button would be pressed for 5 seconds and then trigger a action accordingly.
With my modifications I came to the following bit of code.
#include <Bounce2.h> // library that handles all the debouncing
#include <elapsedMillis.h> // library to keep track of millis
const int number_of_channels=10; //512 for 512 channels lower if you need both a reciever and sender
byte buffer_channel_arduino[number_of_channels]; //buffer to store filetered DMX data
//create a array of the button pins
const byte defaultbuttonPins[] = {2, 3, 4, 5, 6, 7, 8, 9}; //now you can select any pin in any order
const byte control_channel = 0; // the control channels number 0=1 1=2 etc etc
bool state = false; // set the first state to false
// bit of code that keeps track of timings
elapsedMillis button_held_down; // millis button is held down counts here
int button_hold_time = 5000; // button hold time is at 10 seconds
Bounce defaultbuttonsoverride[sizeof(defaultbuttonPins)]; //creates the buttons variable and links it to the bounce library
for (byte i = 0; i < sizeof(defaultbuttonPins); i++) // creates byte i for 0 to the size of the defaultbuttonPins array
defaultbuttonsoverride[i].attach(defaultbuttonPins[i], INPUT_PULLUP);
artnet_override();
Serial.println(button_held_down);
void artnet_override()
for (byte i=0;i<sizeof(defaultbuttonPins); i++)
defaultbuttonsoverride[i].update(); //defaultbuttonsoverride is needed otherwise all values are stored in same part
if(!defaultbuttonsoverride[i].read() && !defaultbuttonsoverride[i].fell()) //if the button was low and still is low continue
if (button_held_down > button_hold_time) // if the button is hold for the time programmed then continue
buffer_channel_arduino[control_channel] = 0; // sets the control channel value to 0 thus allowing control by the buttons again
state = false; // sets the state to false so the output dmx value becomes 0
return; // no clue why return needs to be here but it won't work without it
button_held_down = 0; // if button is not held down keep resetting the counter to 0
with this bit of code when you have a button connected to pin 3 you can keep this button pressed and the button_held_down value will rise till it reaches 5000 and is reset back to 0 (ofcourse I trigger another action in my code but this is for testing).
At this point I was happy as I thought the code functions as intended however when I tried to do it with a button connected to any of the other pins the counter does not start to rise.
I am guessing that there is a problem with the value of button 0 overwriting the value of for example button 3 on a loop.
Also why do I need to use return;? otherwise the code does not work.
