Hi, I'd like to build a "learning" infrared remote that is able to detect also the frequency of the original remote that I use as source to copy. Is it possible to do this with an IR phototransistor?
I need to do this because some remotes I tested are not working at 38Khz that is (more or less) the standard frequency.
I think with highly optimized code it might be possible to capture a digital signal of 38kHz. But you need an example, it will be very hard to make yourself.
You better try a few different IR receiver modules for 36, 38, and 40kHz.
