Detect Keypress
Im trying to write code to detect key press and do something.
Pseudocode:
if spacebar pressed:
do (action)
I have tried KeyboardController but
#include <KeyboardController.h>
does not register as a library. I'm using 1.8.10
Where is that key? If on a keyboard, how is that keyboard connected to the Arduino? A standard Arduino doesn't have a keyboard attached. Provide much more information about the hardware you're using!
Also, what have you done to install theKeyboardController library? Where is it? Please provide a link to the library also.
I am using my computer keyboard with my arduino attached to it with a USB cable.
I was looking for a download to the keyboard controller library but I could only find the Keyboard library so I tried importing it thinking it would be default.
You cannot connect an USB keyboard to an Arduino UNO (that's the model we expect you to have if you don't specify it)!
Does that mean you just took any random library name and put that into an #include statement and hoped that it may load the correct library? That's rather brave but it's not the way programming works, unfortunately.
pylon:
No. I had seen lots of other posts using the KeyboardController library so i assumed it was a default library or at least a downloadable one so i first tried to use it and then tried to download/install it but i could not find it.
There's a post that talks about connecting a PS2 keyboard (they plugged in to the old green and purple ports on older PC's). You can use that if your keyboard has a PS2 connector on it.
SNEAKY SECRET: You can also use a USB keyboard, you just need to use a USB to PS2 converter. PS2 ports are actually the same as USB ports, but they are round and have 2 dummy pins.
What exactly are you trying to accomplish? Why a keyboard into an Arduino, and not just a button?
The only web pages I find that use a KeyboardController library are about using a USB Host Shield to connect a USB keyboard. Do you use such a hardware?
But I agree with KingDubDub, explain in detail what you're trying to achieve and not how you think it should be done. Maybe we can give you some hints.
