Detect Mac address
I want to detect the mac address for just one time but it writes the mac address on the serial monitor as it's in the loop
how can i make the code writes the name of the mac address if it exists just one time not many times as shown here in the serial monitor
photo attached
The function of this code is to read nearby Wi-Fi traffic in the form of packets. These packets are compared
to a list of MAC addresses we wish to track, and if the MAC address of a packet matches one on the list, we turn
on a colored LED that is linked to the user owning the device. For example, when my roommate comes home, the
transmissions from his phone will be detected and cause the blue LED to turn on until his phone is no longer detected.
#include "./esppl_functions.h"
/*  Define you friend's list size here
 How many MAC addresses are you tracking?
#define LIST_SIZE 2
 * This is your friend's MAC address list
 Format it by taking the mac address aa:bb:cc:dd:ee:ff
 and converting it to 0xaa,0xbb,0xcc,0xdd,0xee,0xff
uint8_t friendmac[LIST_SIZE][ESPPL_MAC_LEN] = {
   {0x08, 0xc5, 0xe1, 0xb1, 0xec, 0x43}
  ,{0xc8, 0x3d, 0xd4, 0xf8, 0x41, 0x2b}
 * This is your friend's name list
 * put them in the same order as the MAC addresses
String friendname[LIST_SIZE] = {
   "note 9 "
  ,"lap"
// start variables package - Skickar 2018 hardware LED for NodeMCU on mini breadboard //
  esppl_init(cb);
/* You cannot use a time delay here to keep the LED on, so will need to use ratio of
detected packets to overall packets to keep LED on for longer. If you try to use a
delay to keep the light on for long enough to be useful, the watchdog timer kills the
process and it dies */
int cooldown = 0; /* This variable will be a cooldown timer to keep the LED on for longer, we'll set it to 1000 if we
detect a packet from a device with a MAC address on the list, and then keep the LED on till we get 1000 packets that
are NOT from any device on the list. */
/* end exparimental variable package */
bool maccmp(uint8_t *mac1, uint8_t *mac2) {
  for (int i=0; i < ESPPL_MAC_LEN; i++) {
    if (mac1[i] != mac2[i]) {
      return false;
  return true;
void cb(esppl_frame_info *info) {
  for (int i=0; i<LIST_SIZE; i++) {
    if (maccmp(info->sourceaddr, friendmac[i]) || maccmp(info->receiveraddr, friendmac[i])) {
      Serial.printf("\n%s is here! :)", friendname[i].c_str());
      cooldown = 10000; // here we set it to 1000 if we detect a packet that matches our list
void loop() { // I didn't write this part but it sure looks fancy.
  esppl_sniffing_start();
  while (true) {
    for (int i = ESPPL_CHANNEL_MIN; i <= ESPPL_CHANNEL_MAX; i++ ) {
      esppl_set_channel(i);
      while (esppl_process_frames()) {
You could use a global flag variable to track whether each friend's MAC has been detected, then only print when that flag has not been set:
bool frienddetected[] = {false, false};
   if (maccmp((info->sourceaddr, friendmac[i]) || maccmp(info->receiveraddr, friendmac[i])) && frienddetected[i] == false) {
      frienddetected[i] = true;
cannot convert 'bool' to 'uint8_t* {aka unsigned char*}' for argument '1' to 'bool maccmp(uint8_t*, uint8_t*)'
it shows this error
Please post your updated sketch.
