Detect motion with IR sensor and dim lights after timer cycle
I'm working on a sketch that uses an IR sensor to detect motion. Once motion is detected I'm using PWM to turn the lights on and set a timer to turn the lights off. I'd like to have the lights dim down at the end of the timer cycle. I'm able successfully analogWrite 255 and 0 to the pin but when I try to fade it just turns the pin off. Here is the function I'm using to do this
int long lightsOn(int alarmPin, int ledPin, int long lights_on, int long delay_m) {
  int alarmValue = digitalRead(alarmPin);
  if (lights_on == 0) { // lights off
    if (alarmValue == LOW){
      // motion detected
      Serial.println(">>> Turning lights on");
      analogWrite(ledPin, 255); // turn them on
      return millis();
  else { // lights on
    if (alarmValue == LOW) {
      // lights are on AND there's motion
      // keep timer start to now
      return millis();
    else {
      int long time_now = millis();
      if ((time_now - lights_on) > delay_m) {
        Serial.println(">>> Turning lights off");
   for(int fadeValue = 255; fadeValue >= 0; fadeValue -=5) { // this line doesn't seem to be doing anything.
    analogWrite(ledPin, fadeValue);   }
      else {
        // use the previous time_on
        return lights_on;
  return 0L;
How can I get this to fade down at the end of the timer cycle?
Here is the sketch in it's entirety.
// example for the PIR motion sensor SE-10
int long delay_time = 500; // 1
int long delay_time_2 = 30000; // 2
int long delay_time_3 = 30000; // 3
int long delay_time_4 = 180000; // 4 + 5
int alarmPin_1 = 8;
int ledPin_1 = 9;
int long time_on_1 = 0;
int alarmPin_2 = 12;
int ledPin_2 = A1;
int long time_on_2 = 0;
int alarmPin_3 = 10;
int ledPin_3 = A3;
int long time_on_3 = 0;
int alarmPin_4 = 7;
int ledPin_4 = A4;
int long time_on_4= 0;
int alarmPin_5 = 2;
int ledPin_5 = A0;
int long time_on_5= 0;
void setup () {
  Serial.begin (9600);
  pinMode(ledPin_1, OUTPUT);
  pinMode(alarmPin_1, INPUT);
  pinMode(ledPin_2, OUTPUT);
  pinMode(alarmPin_2, INPUT);
  pinMode(ledPin_3, OUTPUT);
  pinMode(alarmPin_3, INPUT);
  pinMode(ledPin_4, OUTPUT);
  pinMode(alarmPin_4, INPUT);
  pinMode(ledPin_5, OUTPUT);
  pinMode(alarmPin_5, INPUT);
  analogWrite(ledPin_1, 0);
  digitalWrite(ledPin_2, LOW);
  digitalWrite(ledPin_3, LOW);
  digitalWrite(ledPin_4, LOW);
  digitalWrite(ledPin_5, LOW);
  delay (2000); // it takes the sensor 2 seconds to scan the area around it before it can detect infrared presence.
void loop (){
  time_on_1 = lightsOn(alarmPin_1, ledPin_1, time_on_1, delay_time);
  time_on_2 = lightsOn(alarmPin_2, ledPin_2, time_on_2, delay_time_2);
  time_on_3 = lightsOn(alarmPin_3, ledPin_3, time_on_3, delay_time_3);
  time_on_4 = lightsOn(alarmPin_4, ledPin_4, time_on_4, delay_time_3);
  time_on_5 = lightsOn(alarmPin_5, ledPin_5, time_on_5, delay_time_3);
  delay (10);
 * Return the time that the lights went on.  Zero if they are off
      // motion detected
      return millis();
  else { // lights on
      return millis();
    else {
      //     Serial.println("Millis since motion: "+(time_now-time_on));
        // turn them off
       // analogWrite(ledPin, 0);
    // sets the value (range from 0 to 255):
      else {
        return lights_on;
  return 0L;
Ok, I found it by printing the fadeValue and realized I needed to add a delay.
int alarmPin_1 = 8;
int ledPin_1 = 9;
int ledPin_2 = A1;
int ledPin_3 = A3;
int alarmPin_4 = 7;
int ledPin_4 = A4;
int alarmPin_5 = 2;
int ledPin_5 = A0;
void setup () {
void loop (){
  delay (10);
      // motion detected
      return millis();
  else { // lights on
      return millis();
    else {
        // turn them off
           Serial.println(fadeValue);
         delay(25);
      else {
        return lights_on;
  return 0L;
