I am just getting my head around using my arduino pro mini and would appreciate some guidance. Basically I am trying to detect movement via the PIR, then flash for 5 seconds, and then stop. Sounds simple, but my problem is that during that flashing 5 seconds after initial detection, if another movement is detected, it will continue for another 5 seconds. I only want it to do this once and then begin detection after 5 seconds.
Here is my code
int LED=13; // build in led
int PIR = 2; // pir is on d2
bool alreadyDetected=false; // detect if already detected (true) or not (false)
long unsigned int detectedTime=0; // time when detected
bool ledon=false; // led state
long unsigned int lastLEDflashed=0; // time when led was switched on/off
pinMode(LED,OUTPUT);
pinMode(PIR,INPUT);
// read state of PIR
int pirRead = digitalRead(PIR);
if (alreadyDetected==false and pirRead==HIGH ) {
// If not already deteched and PIR detected something, then set various flags
detected();
} else if (alreadyDetected) {
// already in detected stage. flash led or end detection
if (millis() - detectedTime < 5000) {
// do something for 5 seconds when detected - ie flash led
flashLED();
// 5 seconds has passed since initial detected. set various flags to end detection
endDetect();
// tried to clear buffer but made no odds
digitalRead(PIR);
void flashLED() {
// FLASH EVERY SEC
if (millis() - lastLEDflashed > 1000) {
lastLEDflashed=millis();
ledon=!ledon;
digitalWrite(LED, ledon);
Serial.print("flash"); //output
delay(50);
void endDetect() {
// end detection (ie after 5 seconds). set various flags and turn off led
detectedTime=0;
ledon=false;
lastLEDflashed = 0;
digitalWrite(LED, LOW);
Serial.print("motion ended"); //output
delay(50);
void detected() {
// movement detected. set various flags and light up the led
detectedTime = millis();
ledon=true;
lastLEDflashed = millis();
digitalWrite(LED, HIGH);
alreadyDetected=true;
Serial.print("motion detected"); //output
delay(50);
can anyone see the problem?
