Hi (again),
Well, I'm almost done with my project now.. it works wonders with just 1 key to change states. Mainly because with 1 key, I can use this code for button state change, where a digital pin is read and the button state is changed accordingly:
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
Serial.println("off");
else {
// Delay a little bit to avoid bouncing
delay(50);
lastButtonState = buttonState;
Well, I replaced that button with a keypad now. It's the EventKeypad from the downloadable keypad library. And suddenly it doesnt seem so simple anymore, cause the keypad matrix connects various digital pins in all sorts of patterns to be able to read which key is pushed.
But I still need that button state change function! So how would I change the above to be used for something like this: (pseudo code)
If key pressed = '#'
Run Function1 (also after key '#' is released)
If key pressed = '#' again
Run Function2 (also after key '#' is released)
And so on and so on...
Point is I want the arduino to remember that '#' has been pressed and do Function1, until I press it again, and then it shifts to Function2, and then back when I press again.
An understandable answer in correct code, as I'm rather green, will be really appreciated! ![]()
