Detect strong heat source (soldering iron) on short range (max. 0,3 m)
I'm thinking of building some kind of fume extractor for soldering, using a fan.
But I don't want to let it run all the time nor by pushing a button with a timeout (maybe that too, but that's not a problem).
So I thought how about somehow detecting the heat from the soldering iron directly in front of the device (a few cm). The range needs to be very short, so the iron can sit in it's cradle without triggering the sensor. An advantage is maybe, that the soldering iron (tip) and the solder joint itself is much hotter than the surrounding. Normally there is no other "thing" on the bench that hot, so this would be an ideal trigger. As soon as the heat is gone, the fan turns off. There doesn't need to be a differentiation between many different temperature levels - just "hot" and "not hot". :slight_smile:
I thought of maybe some modified PIR sensor, with a very sharp angle and a very low sensitivity? I don't want it to trigger on "regular" motion - obviously.
Any ideas on how to do something like this? Has anyone done something like this before?
You could use a pyrometer(bolometer?) of the sort used in non-contact thermometers.
Maybe get one that uses I2C
MLX90614. There are other versions of this sensor with narrower field of view.
Thanks for your replies!
I guess I will get one of these. For this simple purpose it feels a little bit of a waste, but I guess there aren't that much sensors of this type around, especially non with integrated I2C support.
