Detect when object is moved
I have a very simple project but I can’t figure out the proper sensor or module to use.
The concept is the following: I want to be able to detect when an object is picked up. Example: a glass sitting on a table. I want to detect when the glass is picked up.
There are quite a few sensors out there that would achieve this: weight, touch...
But I want a much simpler mechanism whereby the glass weight closes a switch, and opens it when the glass is picked up.
I’m just wondering if there is something out of the box that would help me achieve this
Thanks
IF I understand, you want to put a hole through the table so you can add a switch that the object will operate. Is this about the sum of it?
Paul
No, the object will be sitting on a shelf where this switch/module will be installed
How will you detect that the object is not moved, still in place?
I only need to know when the object is moved where I then take an action.
I imagine that something like this would get the job done https://www.amazon.com/dp/B00T6RCGNC/ref=cm_sw_r_cp_api_i_9zl1DbAF97NX9
I just don’t know how to go about wiring this button to an arduino and read its state.
TagLua:
Ok, then you want to mount the switch through a hole in the shelf so the object can press down on it. Is this correct?
Paul
Sounds like what you need is a simple switch, maybe with a plate on it.
Maybe an FSR will also do the job, should be easier to hide (if that's important to you).
I would like to suggest three kinds of sensors:
  1. Force sensor, see project: Arduino - Detect Someone Taking Your Stuff and send Gmail
  2. Ultrasonic Sensor
  3. Magnatic Sensor, see Arduino -Monitoring Door Open
