I am using AD8232 sensor to detect ECG.
I am using Arduino Nano, AD8232 is connected to 3.3V and wiring is:
(AD8232 pin - Adruino Nano pin)
- GND - GND
- 3.3V - 5V
- OUTPUT - A2
- LO- - D11
- LO+ - D10
- SDN - not connected
I am using this code:
int Signal; // holds the incoming raw data. Signal value can range from 0-1024
pinMode(10,INPUT);
pinMode(11,INPUT);
if ((digitalRead(10)==1)||(digitalRead(11)==1)) {
Signal = ""; // no data
else {
Signal = analogRead(A2);
Serial.println(Signal); // print data
delay(1); //Wait for a bit to keep serial data from saturating
Now, this works just fine, I get a series of numbers, which I can draw (could be done even with LibreOffice Calc/Excel) and get ECG "line".
But I would also like to detect heart beat and compute bpm (bets per minute). How to do that?
One option would of course be to introduce a variable called Threshold - if Signal is higher than Treshold, then beat would be detected. In fact, I have found a code, where Treshold has been set to 550. But in my testing Signal has never been over 550. Also, top value of a Signal in R-wave is not always the same...
Another option would be, to detect maximum value, but how to avoid detecting local maximum (PR interval and QT interval)?
I mean, there is also a problem, that someone would not have "ideal" ECG curve, how to detect heart beat in that case?
P. S. What is SDN pin on module?
