void handleTouch() {
unsigned long touchDuration = millis() - pressStartTime;
Serial.print("Touch Duration: "); Serial.println(touchDuration);
Serial.print("Millis: "); Serial.println(millis());
Serial.print("PressStartTime: "); Serial.println(pressStartTime);
pressStartTime = 0;
if (touchDuration < LONG_TOUCH) {
// Long touch detected
//longTouchDetected = true;
Serial.println("Short Touch Detected");
ShortClick();
// Perform actions for long touch
} else if (touchDuration >= LONG_TOUCH){
Serial.println("Long Press Detected");
LongPress();
But it detects short touch all the time and keeps switching to short touch functions every time and donot go to the longtouch. How can i accomplish longtouch when the finger is placed on the touch sensor for a prolonged period of time.
// ESP32 - determine length of time touch T0 is touched
int threshold = 40;
volatile unsigned long touchTimer = 0;
// when T0 is touched note start time
void gotTouch1() {
if (touchTimer == 0)
touchTimer = millis();
delay(1000); // give me time to bring up serial monitor
Serial.println("ESP32 Touch timer Interrupt Test");
touchAttachInterrupt(T0, gotTouch1, threshold); // GPIO4
// check if T0 has been touched (touchTimer>0)
// and then released (touchRead(T0) > threshold)
if ((touchRead(T0) > threshold) && touchTimer > 0) {
Serial.printf("Touch T0 detected for %ld mSec\n", millis() - touchTimer);
touchTimer = 0;
a run on an ESP32 gave
Touch T0 detected for 0 mSec
Touch T0 detected for 1944 mSec
Touch T0 detected for 2264 mSec
Touch T0 detected for 1758 mSec
Touch T0 detected for 1622 mSec
Touch T0 detected for 1942 mSec
Touch T0 detected for 1224 mSec
Touch T0 detected for 696 mSec
Touch T0 detected for 6487 mSec
Touch T0 detected for 1 mSec
Touch T0 detected for 8231 mSec
on initial touch tends to get a short touch time - could simply ignore such readings
what type of touch panel are you using? you may need to tune threshold and timing
using Microchip 8-way keypad testing button 8 for tap or long touch
code ignores any spurious touch < 5mSec and a tap is < 200mSec touch
// using Microchip 8-way keypad testing button 8 for tap or long touch
int threshold = 40;
void gotTouch1() {
unsigned long timer1 = millis() - touchTimer;
if (timer1 > 5) { // ignore any spurious touch
if (timer1 < 200) // touch less than 200mSec is a tap
Serial.printf("Touch T0 detected for %3ld mSec TAP!\n", millis() - touchTimer);
Serial.printf("Touch T0 detected for %3ld mSec LONG toutch!\n", millis() - touchTimer);
touchTimer = 0;
test run
Touch T0 detected for 31 mSec TAP!
Touch T0 detected for 28 mSec TAP!
Touch T0 detected for 86 mSec TAP!
Touch T0 detected for 138 mSec TAP!
Touch T0 detected for 59 mSec TAP!
Touch T0 detected for 82 mSec TAP!
Touch T0 detected for 57 mSec TAP!
Touch T0 detected for 902 mSec LONG toutch!
Touch T0 detected for 849 mSec LONG toutch!
Touch T0 detected for 623 mSec LONG toutch!
Touch T0 detected for 543 mSec LONG toutch!
Touch T0 detected for 131 mSec TAP!
Touch T0 detected for 53 mSec TAP!
Touch T0 detected for 33 mSec TAP!
Touch T0 detected for 60 mSec TAP!
Touch T0 detected for 777 mSec LONG toutch!
