Hello i was wondering something about Detecting voltages on the arduino uno. My project i would like to detect the minimum voltage for the arduino problem is the source of the voltage can be as low as half of a volt. All i wanted to do is light up a led that's all. Is it possible to detect a low voltage of a half of a volt?
Hello thank you for the reply back what I'm trying to do is max voltage is 1v it can put out but it can be as low as a half of a volt what I like to do is light up a led or maybe pwm the led at a later time. So if it's like half of a volt can make the led half the brightness and if at .75vcan be 3/4 way brightness and if at a full 1 volt then 100% of the. Brightness of the led. But for now just testing a off and on process when voltage is there.
