Detection object in water
Hello guys, i want to detect object in water. For example when laser line touches object in water (not in sea, rock in water cup), i want to get signal like 0 and 1. I don t even need distance. Just want to see when distance have changed, i want to see. How can i do that? My object that i want to detect is not big that much.
Hello abceyhun
Welcome to the worldbest Arduino forum ever.
Use a cam simply.
Can you recommend cam for me which i can use in my project. Also, I am looking for something cheap
Displacement ?
Weight ?
Beam pass-through / obstruction ?
More detail, perhaps photo or diagram ?
Oh sorry, distance is under 15 cm,
it will pass through glass which contains hot water
when object like rock touched to the ground, i want to get alert. I want to detect it from outside not inside
You can also try to use a light barrier.
so you have a transparent glass pipe with hot water flowing flowing through it and from time to time a rock can be dragged into the pipe and you want to detect that. Did I get that right?
HI,
Is the pipe transparent?
Will the objects you wish to detect cast a shadow, that is are they opaque?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
I have glass of water. It is transparent. There is a sealing rock. When rock touched the ground, i want to get alert. I can no place anything inside this water.
Hi, @abceyhun
Is this a school/college/university project?
What do you mean by "sealing" rock?
I think we have a translation probem.
Can you please tell us your native language?
Do you mean when the rock has fallen to the bottom of the glass.
Thanks... Tom... :grinning: :+1: :coffee: :australia:
so you have something like this
and you want to detect the last stage, when a rock is at the bottom of the glass?
yes exactly, can you also tell me how did u do this animation. Which program or website :smiley: ?
Hi, @abceyhun
Can you please tell us your electronics, programming, arduino, hardware experience?
PLEASE answer post #10.
Thanks.. Tom... :grinning: :+1: :coffee: :australia:
it's just using keynote (powerpoint like but better — a free app) on my Mac and a couple pictures. No rocket science there :slight_smile:
May be as suggested by @paulpaulson a light barrier if reflexion and refraction are not an issue.
Light sensor at bottom of glass (on outside) Dark =rock
