I need to determine the number of items per line in a csv file.
The arduino is reading a csv file from an sdcard.
The csv file is semicolon separated, (
Before i can work with the values from a record ( gathered via parseint() its imperatie to know how many values there are in a record (one line)
The csv file can be updated once and a while, and that should not result in update the sketch in the arduino.
Therefore i need a piece of as simple as possible code to read the number of values per record during setup.
There should be a smart trick to count the number of semicolums in a line for instance
As usual the Devil is in the detail. For instance we don't know whether the data will always end in a semicolon, never end in a semicolon or will sometimes end in a semicolon
Good point. It would, of course, help to know the exact format of the data such as whether it always ends in a semicolon, never ends in a semicolon or sometimes ends in a semicolon
Meanwhile, consider this revised version of the code
Serial.println(countItems("1;2;3;4;5;6;"));
Serial.println(countItems("Mary;had;a;little;lamb"));
Serial.println(countItems(""));
byte countItems(char * line)
Serial.println(line);
if (strlen(line) == 0)
return 0;
byte count = 1;
for (int c = 0; c < strlen(line); c++)
if (line[c] == ';')
count++;
if (line[strlen(line) - 1] == ';') // ends with a semicolon
count--;;
return count;
