Determining and printing a remainder in ardunio IDE
Making a ultrasonic tape measure, using a LV Maxbotiz ez sensor.
using the following code I can output my reading IN feet or inchs. I was wondering using the arduino IdE how do I code and print my remainder so My sensor will display correctly
Example, Even though I am reading 4 foot 5 inchs from my sensor I dont know how to display 4 and X inches.
Here is the code I got from max Botix
I read something about the modulo operator, but I am unsure how to correctly integrate this into my example.
const int anPin1 = 0;
long distance1;
  Serial.begin(9600);  // sets the serial port to 9600
void read_sensors(){
  Scale factor is (Vcc/512) per inch. A 5V supply yields ~9.8mV/in
  Arduino analog pin goes from 0 to 1024, so the value has to be divided by 2 to get the actual inches
  distance1 = analogRead(anPin1)/2;
void print_all(){
  Serial.print("S1");
  Serial.print(" ");
  Serial.print(distance1 /12);
  Serial.print("feet");
  read_sensors();
  print_all();
  delay(50);
I will likely figure it out, but I can see there are a ton of people on here with WAY more coding time then my self.
Thanks in advance
For example:
Or
   int feet = distance / 12;
   int inches = distance - (feet * 12);
(assuming distance is in inches)
PaulS:
Or
Isn't modulo faster than this ?
guix:
Does it really matter?
No.
