Determining i2c Address for Sparkfun TMP006 Sensor
I am using the TMP006 thermopile to collect thermal data on a target area, using the library provided on Sparkfun’s website. The code works fine, but I have to make a modification. The i2c address is defined in the code as 0x40. It then instructs you to put the outputs into pins A4 and A3. When I do this, all is well, but I need pin A4 and A5 to connect two arduinos together. When I change the pin, the i2c address must change because the program hangs when it first uses the new i2c address in TMP006_config(). I had tried using nick gammon’s i2c address finder, but it couldn’t find an i2c-using device. Any ideas or methods for determing i2c addresses? Thanks!
The declaration:
#include <SPI.h>
#include <SD.h>
#include <stdint.h>
#include <math.h>
#include <Wire.h>
#include "I2C_16.h"
#include "TMP006.h"
Sd2Card card;
SdVolume volume;
SdFile root;
File userFile;
uint8_t sensor1 = 0x40; // I2C address of TMP006, can be 0x40-0x47      //  <--Declaration. I have tried the suggested
uint16_t samples = 4; // # of samples per reading, can be 1/2/4/8/16     //values to no avail. There is only 8, right?
int wait = 15;
int sensorValue;
int sound[5];
int temp[5];
boolean go = true;
String userInput;
boolean pool;
int delay3 = 0;
int delay4 = 0;
int delay5 = 0;
int delay6 = 0;
int delay7 = 0;
int delay8 = 0;
float count;
float seconds;
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  Serial.println("Searching for SD Card...");
  if (!SD.begin(10)) {
    Serial.println("Cannot find SD card.");
  while (!Serial) {                                                      // Open serial communications and wait for port to open:
    delay(100);
  Serial.println("\nInitializing SD card...");
  if (!card.init(SPI_HALF_SPEED, 10)) {                                  //***10 used to be: chipSelect***
    Serial.println("initialization failed.");
    go = false;
    return;
  else {
    Serial.println("Card Initialized");
  Serial.println("here");
  int sensor_temp = readDieTempC(sensor1);
  config_TMP006(sensor1, samples);                                 //***Hangs here
Code I use from Library:
// Configures sensor, use before reading from it
void config_TMP006(uint8_t addr, uint16_t samples)
  Wire.begin();
  write16(addr, TMP006_CONFIG, samples | TMP006_CFG_MODEON | TMP006_CFG_DRDYEN);
// Calculate object temperature based on raw sensor temp and thermopile voltage
double readObjTempC(uint8_t addr)
  double Tdie = readRawDieTemperature(addr);
  double Vobj = readRawVoltage(addr);
  Vobj *= 156.25;  // 156.25 nV per LSB
  Vobj /= 1000000000; // nV -> V
  Tdie *= 0.03125; // convert to celsius
  Tdie += 273.15; // convert to kelvin
  // Equations for calculating temperature found in section 5.1 in the user guide
  double tdie_tref = Tdie - TMP006_TREF;
  double S = (1 + TMP006_A1*tdie_tref +
      TMP006_A2*tdie_tref*tdie_tref);
  S *= TMP006_S0;
  S /= 10000000;
  S /= 10000000;
  double Vos = TMP006_B0 + TMP006_B1*tdie_tref +
    TMP006_B2*tdie_tref*tdie_tref;
  double fVobj = (Vobj - Vos) + TMP006_C2*(Vobj-Vos)*(Vobj-Vos);
  double Tobj = sqrt(sqrt(Tdie * Tdie * Tdie * Tdie + fVobj/S));
  Tobj -= 273.15; // Kelvin -> *C
  return Tobj;
If you are using an I2C device, it MUST be connected to the I2C pins. Changing the pins it is connected to is NOT a possibility, unless you have an Arduino with multiple I2C ports (like the Due). If you do, then you need to change the I2C instance, not the device address.
