How do i determine the resistor value when using different size seven segment displays with a MAX7219?
For example 4, 2-Diigit displays. Or 2 3-Digit and, 1 1-Digit?
Is that possible? I have specs for 7 Segment displays. They refer to Forward Voltage Vf/seg and Luminous Iv/seg
Here is example of my 2 Digit Display.
5V - 2.3V / .02mA = 135ohms
Is this correct? Or do i multiply by for each segment of the digit?
You could use a 100k potentiometer. With that table, looks like you'd want a minimum setting as well, so put a 10k resistor in series with the 100k pot.
If you have dissimilar LEDs wired to the same 7219(e.g. 4 red 7-segment and 2 green 7-segment), you'll have to come up with a compromise, because there's only one R-set.
You’re welcome. The MAX7219 has lots of options that you can set in software. If you’re curious, read the data sheet and study the software library documentation.
