Determining mechanical vibration frequency with MPU6050
I had barely any idea where to start with this, and googling generally led to things I didn't understand. I tried asking the very controversial AI to do it for me, but haven't had much luck there either. I think the closest I saw was on a Korean(?) guy's blog, which I'll include below, but I need it to output the frequency over serial, and it seems to be determining the amplitude instead.
//---------- 16x2 LCD ---------------------------------------------------------------------------
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
//---------- I2C --------------------------------------------------------------------------------
#include<Wire.h>
//---------- MPU6050 Measurement & Filtering Range ----------------------------------------------
#define AFS_SEL 2  // Accelerometer Configuration Settings   AFS_SEL=2, Full Scale Range = +/- 8 [g]
#define DLPF_SEL  0  // DLPF Configuration Settings  Accel BW 260Hz, Delay 0ms / Gyro BW 256Hz, Delay 0.98ms, Fs 8KHz
//---------- Variables for gravity --------------------------------------------------------------
const int MPU_ADDR=0x68;  // I2C address of the MPU-6050
int AcX,AcY,AcZ;  // Accelerometer values
long Cal_AcX, Cal_AcY, Cal_AcZ; // Calibration values
float GAcX, GAcY, GAcZ; // Convert accelerometer to gravity value
float Min_GAcX=0, Max_GAcX=0, PtoP_GAcX, Min_GAcY=0, Max_GAcY=0, PtoP_GAcY, Min_GAcZ=0, Max_GAcZ=0, PtoP_GAcZ; // Finding Min, Max & Peak to Peak of gravity value
float Min = 0, Max = 0; // Initial value of Min, Max
int cnt; // Count of calibration process
float Grvt_unit; // Gravity value unit
long period, prev_time; // Period of calculation
void setup(){
  Wire.begin();
  init_MPU6050();
  lcd.begin(16, 2);
  Gravity_Range_Option();
  Calib_MPU6050(); // Calculating calibration value
void loop(){
  ReadDate_MPU6050();
  Calc_Grvt();
  Display_Grvt();
void init_MPU6050(){
  //MPU6050 Initializing & Reset
  Wire.beginTransmission(MPU_ADDR);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
  //MPU6050 Clock Type
  Wire.write(0x03);     // Selection Clock 'PLL with Z axis gyroscope reference'
  //MPU6050 Accelerometer Configuration Setting
  Wire.write(0x1C);  // Accelerometer Configuration register
  if(AFS_SEL == 0) Wire.write(0x00);     // AFS_SEL=0, Full Scale Range = +/- 2 [g]
  else if(AFS_SEL == 1) Wire.write(0x08);     // AFS_SEL=1, Full Scale Range = +/- 4 [g]
  else if(AFS_SEL == 2) Wire.write(0x10);     // AFS_SEL=2, Full Scale Range = +/- 8 [g]
  else  Wire.write(0x18);     // AFS_SEL=3, Full Scale Range = +/- 10 [g]
  //MPU6050 DLPF(Digital Low Pass Filter)
  Wire.write(0x1A);  // DLPF_CFG register
  if(DLPF_SEL == 0) Wire.write(0x00);     // Accel BW 260Hz, Delay 0ms / Gyro BW 256Hz, Delay 0.98ms, Fs 8KHz
  else if(DLPF_SEL == 1)  Wire.write(0x01);     // Accel BW 184Hz, Delay 2ms / Gyro BW 188Hz, Delay 1.9ms, Fs 1KHz
  else if(DLPF_SEL == 2)  Wire.write(0x02);     // Accel BW 94Hz, Delay 3ms / Gyro BW 98Hz, Delay 2.8ms, Fs 1KHz
  else if(DLPF_SEL == 3)  Wire.write(0x03);     // Accel BW 44Hz, Delay 4.9ms / Gyro BW 42Hz, Delay 4.8ms, Fs 1KHz
  else if(DLPF_SEL == 4)  Wire.write(0x04);     // Accel BW 21Hz, Delay 8.5ms / Gyro BW 20Hz, Delay 8.3ms, Fs 1KHz
  else if(DLPF_SEL == 5)  Wire.write(0x05);     // Accel BW 10Hz, Delay 13.8ms / Gyro BW 10Hz, Delay 13.4ms, Fs 1KHz
  else  Wire.write(0x06);     // Accel BW 5Hz, Delay 19ms / Gyro BW 5Hz, Delay 18.6ms, Fs 1KHz
void Gravity_Range_Option(){
  switch(AFS_SEL) { // Selecting Gravity unit value
    case 0:
      Grvt_unit = 16384;
    case 1:
      Grvt_unit = 8192;
    case 2:
      Grvt_unit = 4096;
    case 3:
      Grvt_unit = 3276.8;
void Calib_MPU6050() {
  for(int i = 0 ; i < 2000 ; i++) { // Summing Iteration for finding calibration value
    if(i % 200 == 0) {  // Display progress every 200 cycles
      cnt++;
      if(cnt == 1)  { // Characters to display first
        Serial.print("Calculating .");
        lcd.clear();
        lcd.setCursor(0,0);
        lcd.print("Calculating");
        lcd.setCursor(0,1);
        lcd.print(".");
      else  { // Display progress by point
        Serial.print(".");
        lcd.print(".");
    ReadDate_MPU6050(); // Read Accelerometer data
    delay(10);
    // Sum data
    Cal_AcX += AcX;
    Cal_AcY += AcY;
    Cal_AcZ += AcZ;
  // Average Data
  Cal_AcX /= 2000;
  Cal_AcY /= 2000;
  Cal_AcZ /= 2000;
  // Serial Print
  Serial.println("");
  Serial.println("End of Calculation");
  Serial.print("Cal_AcX = "); Serial.print(Cal_AcX);
  Serial.print(" | Cal_AcY = "); Serial.print(Cal_AcY);
  Serial.print(" | Cal_AcZ = "); Serial.println(Cal_AcZ);
  // LCD Display
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("CalibValue X|Y|Z");
  lcd.setCursor(0,1);
  lcd.print(String(Cal_AcX) + "|" + String(Cal_AcY) + "|" + String(Cal_AcZ));
  delay(2000);
void ReadDate_MPU6050() {
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  //Wire.requestFrom(MPU_ADDR,14,true);  // request a total of 14 registers
  Wire.requestFrom(MPU_ADDR,6,true);  // request a total of 14 registers
  AcX=Wire.read()<<8|Wire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  AcY=Wire.read()<<8|Wire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  AcZ=Wire.read()<<8|Wire.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
void Calc_Grvt() {
  AcX = (AcX - Cal_AcX);  // Calibrated Accelerometer value
  AcY = (AcY - Cal_AcY);  // Calibrated Accelerometer value
  AcZ = (AcZ - Cal_AcZ);  // Calibrated Accelerometer value
  GAcX = AcX / Grvt_unit; // Converting the Calibrated value to Gravity value
  GAcY = AcY / Grvt_unit; // Converting the Calibrated value to Gravity value
  GAcZ = AcZ / Grvt_unit; // Converting the Calibrated value to Gravity value
  //---------- Calculating Min, Max & Peak to Peak of Gravity --------------------------------------
  Min_GAcX = min(Min_GAcX, GAcX);
  Max_GAcX = max(Max_GAcX, GAcX);
  PtoP_GAcX = Max_GAcX - Min_GAcX;
  Min_GAcY = min(Min_GAcY, GAcY);
  Max_GAcY = max(Max_GAcY, GAcY);
  PtoP_GAcY = Max_GAcY - Min_GAcY;
  Min_GAcZ = min(Min_GAcZ, GAcZ);
  Max_GAcZ = max(Max_GAcZ, GAcZ);
  PtoP_GAcZ = Max_GAcZ - Min_GAcZ;
void Display_Grvt() {
  //---------- Serial print ----------------------------------------------------------------------
  Serial.print("AcX= " + String(AcX));
  Serial.print(" |AcY= " + String(AcY));
  Serial.println(" |AcZ= " + String(AcZ));
  //---------- LCD Display -----------------------------------------------------------------------
  period = millis() - prev_time;
  if(period > 1000) {
    prev_time = millis();
    lcd.clear();
    lcd.setCursor(0,0);
    lcd.print("PeakToPeak X|Y|Z");
    lcd.setCursor(0,1);
    lcd.print(String(PtoP_GAcX) + "|" + String(PtoP_GAcY) + "|" + String(PtoP_GAcZ));
    Min_GAcX = 0;
    Max_GAcX = 0;
    Min_GAcY = 0;
    Max_GAcY = 0;
    Min_GAcZ = 0;
    Max_GAcZ = 0;
There's also one or two posts talking about using MATLAB to calculate it, but that costs money and I'm not paying for it.
The code the AI made seems to make sense, but because it's not up-to-date, it doesn't know how to handle the libraries quite right. Using arduinoFFT v 1.6.0, this code compiles correctly, but doesn't do what I'd like it to.
#include <Wire.h>
#include <MPU6050.h>
#include <arduinoFFT.h>
MPU6050 mpu;
arduinoFFT fft;
int16_t ax, ay, az;
float frequencies[512];
float magnitudes[512];
  Wire.begin();
  mpu.initialize();
  fft.Windowing(FFT_WIN_TYP_HAMMING, FFT_FORWARD);
  Serial.println(mpu.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
  mpu.getAcceleration(&ax, &ay, &az);
  float values[512];
  for (int i = 0; i < 512; i++) {
    values[i] = (float)az;
    digitalWrite(13, HIGH);
    delayMicroseconds(1000);
    digitalWrite(13, LOW);
  fft.Compute(/*values, NULL, 512, */FFT_FORWARD);
  fft.ComplexToMagnitude();
  fft.MajorPeak(/*frequencies*/);
  float frequency = frequencies[0];
  Serial.print("Vibrational frequency: ");
  Serial.print(frequency);
  Serial.println(" Hz");
If anyone can figure out how to change this to work correctly or provide their own solution, I'd be thrilled.
Also, if the Klipper firmware for 3D printers can use an MPU6050 to calculate resonance, then it stands to reason that there should be other code that can do it too, so please don't suggest just buying another product or saying the MPU6050 isn't accurate enough for this. Cheers :wink:
Possible clues for how to do this could be located here: Measuring Resonances - Klipper documentation
The python script they use to calibrate the shaping automatically is shown here and the calculating scripts are here
How many frequencies are you interested in? Mechanical vibrations, even the fundamental are accompanied by many overtone frequencies and not all are even multiples for the fundamental.
Lower frequencies. My example was pretty close to home, as my intent is to use the system to calculate the values for Input Shaping on my printer. Marlin docs say about 15-60Hz, so ideally that range. (but a little wider probably couldn't hurt, especially if I could change those limit values "on the fly".)
Does it matter which axis is doing the vibration?
Not really. So long as I can get the absolute acceleration—without gravity—it should be good. But a per-axis readout would be nice to have.
Actually, just had a brain wave. Not able to test it just yet, so please bear with me.
Would (sqrt((a.acceleration.x * a.acceleration.x) + (a.acceleration.y * a.acceleration.y) + (a.acceleration.z * a.acceleration.z))) == some_variable and then zeroing that variable work?
Of course, after that variable is zeroed while the IMU is unmoving, then I would attach it to the printer and record the absolute acceleration value over time. If I have something else record the data and then put it through the python offline processing scripts provided by Klipper, since the documentation states that the scripts will accept .csv files, I expect it just might.
If I've solved my own problem, please let me know!
And don't worry, I can probably google how to zero a variable by offsetting it on my own.
Additionally, zeroing all the axes individually and getting their readout shouldn't be too difficult so long as the IMU is fixed to the resonating platform, right?
