Dev Board with Lora, MC and Battery Connection
Hi. I'm trying to find a dev board with a microcontroller, serial connection, integrated LoRa module and a battery connection (to run it standalone). I found some but quite expensive (u$d 100). Do you know any affordable option for prototyping?
Thanks very much.
fernando
Hi @fer_ruscitti ,
not sure if you're in the US..
quick search on amazon..
ESP32 Development Board SX1262 863 928MHz LoRaWAN WiFi Bluetooth Dual Core 240MHz Integrated CP2102 with 0.96" OLED Display and Antenna for Arduino
2 for $50..
still have to get batts..
good luck.. ~q
+1, Those Heltec boards are very reasonable.
For the case shown in the link there is a clip on battery holder available to which you can fit a 102040 Lithium battery and switch.
Apart from the Heltec boards, Lilygo make a range of LoRa boards as well, their LilyGo T3 V1.6.1 is reasonably priced too.
I saw the HiLetgo first, about the same price..
but they were not soldered..
I like to buy them soldered from the factory..
I have used Lilygo before, idk, i tend to find them all working..
~q
