Devantec SRF10, SRF08
Hi all,
I'm trying to read the output of this two sensors with M5Stack SRF10, SRF08 but I'm really far about max distance sensing...
max distance displayed is about 2 mt
this is the scketch:
// I2C SRF10 or SRF08 Devantech Ultrasonic Ranger Finder
// by Nicholas Zambetti <http://www.zambetti.com>
// and James Tichenor <http://www.jamestichenor.net>
// Demonstrates use of the Wire library reading data from the
// Devantech Utrasonic Rangers SFR08 and SFR10
// Created 29 April 2006
// This example code is in the public domain.
#include <Wire.h>
  Wire.begin();                // join i2c bus (address optional for master)
  Serial.begin(9600);          // start serial communication at 9600bps
int reading = 0;
  // step 1: instruct sensor to read echoes
  Wire.beginTransmission(112); // transmit to device #112 (0x70)
  // the address specified in the datasheet is 224 (0xE0)
  // but i2c adressing uses the high 7 bits so it's 112
  Wire.write(byte(0x00));      // sets register pointer to the command register (0x00)
  Wire.write(byte(0x51));      // command sensor to measure in "inches" (0x50)
  // use 0x50 for inc
  // use 0x51 for centimeters
  // use 0x52 for ping microseconds
  Wire.endTransmission();      // stop transmitting
  // step 2: wait for readings to happen
  delay(70);                   // datasheet suggests at least 65 milliseconds
  // step 3: instruct sensor to return a particular echo reading
  Wire.write(byte(0x02));      // sets register pointer to echo #1 register (0x02)
  // step 4: request reading from sensor
  Wire.requestFrom(112, 2);    // request 2 bytes from slave device #112
  // step 5: receive reading from sensor
  if (2 <= Wire.available()) { // if two bytes were received
    reading = Wire.read();  // receive high byte (overwrites previous reading)
    reading = reading << 8;    // shift high byte to be high 8 bits
    reading |= Wire.read(); // receive low byte as lower 8 bits
    Serial.println(reading);   // print the reading
  delay(250);                  // wait a bit since people have to read the output :)
// The following code changes the address of a Devantech Ultrasonic Range Finder (SRF10 or SRF08)
// usage: changeAddress(0x70, 0xE6);
void changeAddress(byte oldAddress, byte newAddress)
  Wire.beginTransmission(oldAddress);
  Wire.write(byte(0xA0));
  Wire.write(byte(0xAA));
  Wire.write(byte(0xA5));
  Wire.write(newAddress);
and this the serial monitor output:
200
210
190
210
220
190
190
190
210
210
190
190
190
220
there's the capacitor and I tried also with pull-up resistors on I2C line....
tnk a lot
You might want to post your schematic, not a frizzy thing. I find the following: It appears that you may have more then one on the buss. I suggest you work with only one until you get it working. Be sure of the pull up resistors on the I2C buss.
Changing the I2C Bus Address:
To change the I2C address of the SRF10 you must have only one sonar on the bus. Write the 3 sequence commands in the correct order followed by the address. Example; to change the address of a sonar currently at 0xE0 (the default shipped address) to 0xF2, write the following to address 0xE0; (0xA0, 0xAA, 0xA5, 0xF2 ). These commands must be sent in the correct sequence to change the I2C address, additionally, No other command may be issued in the middle of the sequence. The sequence must be sent to the command register at location 0, which means 4 separate write transactions on the I2C bus. When done, you should label the sonar with its address, however if you do forget, just power it up without sending any commands. The SRF10 will flash its address out on the LED. One long flash followed by a number of shorter flashes indicating its address. The flashing is terminated immediately on sending a command the SRF10. Take care not to set more than one sonar to the same address, there will be a bus collision and very unpredictable results.
tnks a lot,
I'm trying one by one and not the two sensors together... both give me quite the same output...
I'm following this example with this setup
with M5Stack connected on 21/22 pin (SDA/SCL).
those pin have already pull-up resistors
