Development code
I have modified a programa that reads by rf comunication the data sent from the transmitter, showing on the computer screen. I´d like to insert a routine to light a led when the transmitter stops sending. In fact I want light two led cause the transmitter sends in two chanels at the same time. If one of this channels stops sending the corresponding led will have the light on. I´m not being able to to this routine. I think that it must be done with a timer that will read when the transmission stops after a certain time and activate an interrupt to put the corresponding pin high, but I don´t know how to do this. I need some help. This is my code.
  • KeeyLoq
  • Rotina básica para decodificar um sinal
  • PWM do transmissor rfPICK
#include “TimerOne.h” // biblioteca de temporizacao
int ledPin = 13; // LED ligado no pino 13
int rxPin = 11; // RxDATA do receptor Microchip
int rxSample;
int rxEnabled;
#define TE 400 // us
#define OVERSAMPLING 3 // Taxa de sobre-amostragem
#define NBIT 65 // numero de bits a receber -1
unsigned char B[9]; // buffer de recepcao
volatile int RFstate; // estado do receptor
volatile int RFcount; // timer
volatile int Bptr; // indice para o buffer de recepcao
volatile int BitCount; // contador de bits recebidos
volatile int XTMR; // contador (software) de 16 bit
volatile int RFFull; // buffer cheio
volatile int RFBit; // amostra do sinal de RF
static int seq;
#define TRFreset 0
#define TRFSYNC 1
#define TRFUNO 2
#define TRFZERO 3
#define TRUE 1
#define FALSE 0
#define HIGH_TO -10 // Te maximo
#define LOW_TO 10 // Te minimo
#define SHORT_HEAD 20 // minimo Thead aceito 2,7ms
#define LONG_HEAD 45 // maximo Thead aceito 6,2ms
#define LEDCOUNT 3750 // pisca o led a 1 Hz (1/133us/2)
volatile int RFstate_flg;
RFstate_flg = 0;
pinMode(ledPin, OUTPUT);
pinMode(rxPin, INPUT);
Serial.println(“Keeylooq…”);
InitReceiver();
rxEnabled = 1;
Timer1.initialize(133); // initializa timer1 (133 uSecs - TE/OVERSAMPLING)
Timer1.attachInterrupt(callback); // instala callback() como interrupcao de “timer overflow”
Serial.print(" Periodo: ");
Serial.println(Timer1.pwmPeriod, DEC);
int i;
if (XTMR > LEDCOUNT-1)
XTMR = 0;
digitalWrite(ledPin, !digitalRead(ledPin));
if (RFFull == 1)
for (i=0; i < 9; i++) //(NBIT+1)/8; i++)
Serial.print(B*, HEX);*
  • Serial.print(" ");*
  • Serial.print("[");*
  • Serial.print(seq++, DEC);*
  • Serial.println("]");*
  • RFFull = 0;*
    void callback()
  • rxSample = digitalRead(rxPin); // amostra do pino de entrada (RF)!!!*
  • XTMR++;*
  • if (rxEnabled == 1)*
  • rx_isr(); *
    void rx_isr()
  • // esta rotina eh executada toda vez que o Timer1 interrompe*
  • RFBit = rxSample; *
  • if (RFFull == 1) // buffer cheio !*
  • return;*
  • switch( RFstate) // ponto de entrada da maquina de estado*
  • case TRFUNO:*
  • if ( RFBit == 0)*
  • { // transicao negativa detectada ----+*
  • RFstate= TRFZERO;*
  • RFstate_flg |=1;*
  • else*
  • { // enquanto nivel-alto*
  • RFcount–;*
  • if ( RFcount < HIGH_TO)*
  • RFstate = TRFreset; // reset se demorar muito*
  • RFstate_flg |=1;*
  • break;*
  • case TRFZERO:*
  • if ( RFBit == 1)*
  • { // transicao positiva detectada ±—*
  • RFstate= TRFUNO;*
  • RFstate_flg |=8;*
  • B[Bptr] >>= 1; // desloca o byte para direita*
  • if ( RFcount >= 0)*
  • B[Bptr]+=0x80; // insere um novo bit na posicao 7*
  • RFcount = 0; // reseta o contador de tamanho*
  • if ( ( ++BitCount & 7) == 0)*
  • Bptr++; // proximo byte*
  • if (BitCount == NBIT)*
  • RFstate = TRFreset; // fim da recepcao*
  • RFstate_flg |=1;*
  • RFFull = TRUE;*
  • else*
  • { // ainda nivel-baixo*
  • RFcount++;*
  • if ( RFcount >= LOW_TO) // nivel-baixo muito longo*
  • RFstate = TRFSYNC; // volta para o estado de sincronismo…*
  • Bptr = 0; // reseta ponteiro, mas continua contando…*
  • BitCount = 0;*
  • RFstate_flg |=2; *
  • break;*
  • case TRFSYNC:*
  • if ( RFBit == 1)*
  • { // transicao positiva detectada ±–+ ±–…*
  • // | | <-Theader-> | *
  • if ( ( RFcount < SHORT_HEAD) || ( RFcount >= LONG_HEAD))*
  • RFstate = TRFreset;*
  • RFstate_flg |=1;*
  • break; // muito curto/longo – header invalido*
  • else*
  • RFcount =0; // reinicializa contador*
  • RFstate= TRFUNO;*
  • RFstate_flg |=4;*
  • else*
  • RFcount++;*
  • break;*
  • case TRFreset:*
  • default:*
  • RFstate = TRFSYNC; // reinicializa a maquina de estado*
  • RFstate_flg |=1;*
  • RFcount = 0;*
  • Bptr = 0;*
  • BitCount = 0;*
  • break;*
  • } // switch*
} // rx_isr
void InitReceiver()
  • RFstate = TRFreset; // inicializa a maquina de estado*
  • RFstate_flg |=1;*
  • RFFull = 0; // inicia com o buffer vazio*
  • XTMR = 0; // inicia o timer por software*
Please do not post great big long reams of code. There is a CODE button right above where you type your text when making a post. Click that, then past your code inbetween the inserted tags. That way we don't have to scroll down pages and pages to read your post. Thanks.
