viv_g
October 26, 2016, 7:59am
1
Hey guys,
Originally tried to flash a bootloader onto a project i was working on, i had an atmega328-au smd chip, so I edited the avrude.conf file to allow it to recognise its signature.
I have attached the code in the comment below as it was above the 9000 characted limit.
The device uses a ceramic resonator, so the crystal should not be the problem...
I had no luck trying to get any response from the device, so i swapped out another atmega328p-au chip for the original. I still am getting the 0x0000 error message.
At least originally It was possible to read back the signature of the device. Now I am getting nothing at all...
Any ideas?
Here is a link to the schematic https://github.com/kveilands/SAAB-CDC/blob/master/Bluesaab%20RN52%20v4.1%20sch.pdf
And here is a link to the pcb https://github.com/kveilands/SAAB-CDC/blob/master/Bluesaab%20RN52%20v4.1%20pcb.pdf
I am getting 3.3v on the vcc pins of the atmega, not really sure what to do next....
Any advice??
Cheers,
Viv
viv_g
October 26, 2016, 8:09am
2
Part 1:
Arduino: 1.6.8 (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega328"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9514
avrdude: erasing chip
avrdude: reading input file "0x3F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x05"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0x05:
avrdude: load data efuse data from input file 0x05:
avrdude: input file 0x05 contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDA"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDA:
avrdude: load data hfuse data from input file 0xDA:
avrdude: input file 0xDA contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
viv_g
October 26, 2016, 8:14am
3
Part 2:
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -Uflash:w:C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:i -Ulock:w:0x0F:m
Using Port : COM4
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
avrdude: writing flash (32670 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 32670 bytes of flash written
avrdude: verifying flash memory against C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: load data flash data from input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: input file C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex contains 32670 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.00s
avrdude: verification error, first mismatch at byte 0x7800
0x00 != 0x0c
avrdude: verification error; content mismatch
Error while burning bootloader
viv_g
October 26, 2016, 8:23am
4
And here is the error code I am getting at the moment
Arduino: 1.6.12 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Viv\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/bin/avrdude -CC:\Users\Viv\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM4 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Viv\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/etc/avrdude.conf"
Using Port : COM4
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 2
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Device signature = 0x000000 (retrying)
Error while burning bootloader.
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
Thanks for your help guys
Viv
DrAzzy
October 26, 2016, 6:38pm
6
spycatcher2k:
Ah well! getting just a little bit more annoyed!!! >:(
I'm not a guy! So my input is invalid?
"Guys" to refer to a group of mixed genders is widespread, at least in some regions. Where I live, men and women use "guys" to refer to groups of either gender in a friendly manner. It's very strange to see people taking offense to this.
It sounds like bad resonator to me. There are versions of the Arduino as ISP sketch that output a clock signal on pin 9 of the programmer Arduino. Here is one: GitHub - adafruit/ArduinoISP: A fork of the ArduinoISP that has 8mhz output clock
You can attach that signal to the XTAL1 pin of the target chip, and see if it becomes responsive. If it does, then look closer at the resonator and its traces and soldering, for shorts, opens, bad components, etc.
Perhaps I missed them but I don't see any bypass capacitors on the MCU pins.
If they are in fact present, then make it obvious on the schematic and ignore the following rant (or whatever it is).
Why Bypass? Well, it turns out power distribution is sort of like bridge building.
The tension wires have distributed inductance and capacitance and if driven with even a slight flutter at the right frequency can resonate most, unfortunately. In a bridge, the cables carry force while on the board the traces carry current. The mathematics of springs and force is like inductance and current. If I wanted the bridge to not fall down I could sprinkle weights along the tension wires (not evenly) to change the resonance to a place outside the driving force frequency. Well, guess what the bypass is, yes it is like a little weight. It is best to place one at the end of each power distribution trace (each IC is generally a near enough approximation). Good luck with your bridge.
