Hi, I have an ATmega826p + ESP8266 and want to use it in combination with the Arduino IoT cloud. However, creating a device, adding "things" and uploading the sketch together with some code for Over the Air (OTA) code my device status stays offline...
I am not sure what I am missing here or if this problem has to do with the device being some sort of clone. My power source is a Samsung (phone) charger which I believe to be reliable enough for the WIFI module. When uploading the sketch together with a basic LED blink addition the LED actually blinks, so I believe uploading the sketch is not the problem. I am using the desktop Arduino IDE as opposed to the web-based IDE.
All my code is uploaded onto the ESP8266 if not mistaken (using OTA). Below is the code:
BasicOTA
#include <ESP8266WiFi.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "thingProperties.h"
#include "arduino_secrets.h"
const char* ssid = SECRET_SSID;
const char* password = SECRET_PASS;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
// OTA PROGRAM
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
// Port defaults to 8266
// ArduinoOTA.setPort(8266);
// Hostname defaults to esp8266-[ChipID]
ArduinoOTA.setHostname("Pino");
// No authentication by default
ArduinoOTA.setPassword("PinosPassword");
// Password can be set with it's md5 value as well
// MD5(admin) = 21232f297a57a5a743894a0e4a801fc3
// ArduinoOTA.setPasswordHash("21232f297a57a5a743894a0e4a801fc3");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_FS
type = "filesystem";
// NOTE: if updating FS this would be the place to unmount FS using FS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) {
Serial.println("Auth Failed");
} else if (error == OTA_BEGIN_ERROR) {
Serial.println("Begin Failed");
} else if (error == OTA_CONNECT_ERROR) {
Serial.println("Connect Failed");
} else if (error == OTA_RECEIVE_ERROR) {
Serial.println("Receive Failed");
} else if (error == OTA_END_ERROR) {
Serial.println("End Failed");
ArduinoOTA.begin();
ArduinoCloud.update();
ArduinoOTA.handle();
thingProperties.h
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char THING_ID[] = "4d3134c1-5eea-4a99-a085-3e6ef474f58e";
const char DEVICE_LOGIN_NAME[] = "9860b5d2-3575-4063-b0c5-5602f9963cd7";
const char SSID[] = SECRET_SSID; // Network SSID (name)
const char PASS[] = SECRET_PASS; // Network password (use for WPA, or use as key for WEP)
const char DEVICE_KEY[] = SECRET_KEY; // Secret device password
CloudTemperatureSensor tempDown;
CloudTemperatureSensor tempMid;
CloudTemperatureSensor tempUp;
CloudRelativeHumidity humidity;
void initProperties(){
ArduinoCloud.setBoardId(DEVICE_LOGIN_NAME);
ArduinoCloud.setSecretDeviceKey(DEVICE_KEY);
ArduinoCloud.setThingId(THING_ID);
ArduinoCloud.addProperty(tempDown, READ, ON_CHANGE, NULL);
ArduinoCloud.addProperty(tempMid, READ, ON_CHANGE, NULL);
ArduinoCloud.addProperty(tempUp, READ, ON_CHANGE, NULL);
ArduinoCloud.addProperty(humidity, READ, ON_CHANGE, NULL);
WiFiConnectionHandler ArduinoIoTPreferredConnection(SSID, PASS);
Thanks in advance.
