Devices with same address
Hi, So I have two devices with same address when I try pinging it only one gets detected instead of both. Is there away to get around this? Oh and both devices need the SCL and SDA port to run.
You need some thing like this https://www.coolcomponents.co.uk/tca9548a-i2c-multiplexer.html
Mark
Okay so this if for a business and I would need to get clearance to order something like that. Is there some way I can something like that without needing to order that cheap?
Use two gates of 74HC125 - bring SCL into both, enable output to one or the other.
Go ahead, spend 48 cents.
