devo aggiungere un rele a tempo....
#include <EtherCard.h>
static byte mymac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
byte Ethernet::buffer[600];
boolean L1,L2,L3,L4;
const char *sito="http://mio_sito";
void setup () {
  ether.begin(sizeof Ethernet::buffer, mymac, 53);
  ether.hisport = 80;
  ether.dhcpSetup();
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
//  DDRD = B00111100;
  //PORTD |= B00000000;
  L1=L2=L3=L4 = true;
  word len = ether.packetReceive();
  word pos = ether.packetLoop(len);
  if(pos) {
     if(strstr((char *)Ethernet::buffer + pos, "GET /R1") != 0) {
        L1 = !L1;
        digitalWrite(2, L1);
     if(strstr((char *)Ethernet::buffer + pos, "GET /R2") != 0) {
        L2 = !L2;
        digitalWrite(3, L2);
     if(strstr((char *)Ethernet::buffer + pos, "GET /R3") != 0) {
        L3 = !L3;
        digitalWrite(4, L3);
     if(strstr((char *)Ethernet::buffer + pos, "GET /R4") != 0) {
        L4 = !L4;
        digitalWrite(5, L4);
     BufferFiller bfill = ether.tcpOffset();
     bfill.emit_p(PSTR("HTTP/1.0 200 OK\r\n"
                        "Content-Type: text/html\r\nPragma: no-cache\r\n\r\n"
                        "<title>Ardumino 1.0</title>"));
      bfill.emit_p (PSTR("<a href=\"/R1\"><img src=\"$S/lam-$F.jpg\" width=50% height=40%>"), sito, L1 ? PSTR ("off") : PSTR ("on"));
      bfill.emit_p (PSTR("<a href=\"/R2\"><img src=\"$S/cor-$F.jpg\" width=50% height=40%>"), sito, L2 ? PSTR ("off") : PSTR ("on"));
      bfill.emit_p (PSTR("<a href=\"/R3\"><img src=\"$S/wd-$F.jpg\" width=50% height=40%>"), sito, L3 ? PSTR ("off") : PSTR ("on"));
      bfill.emit_p (PSTR("<a href=\"/R4\"><img src=\"$S/hdd-$F.jpg\" width=50% height=40%>"), sito, L4 ? PSTR ("off") : PSTR ("on"));
      bfill.emit_p(PSTR("
<a href=\"/\"><img src=\"$S/agg.png\" width=15% height=15%>"), sito);
      ether.httpServerReply(bfill.position());
questo è il codice che sto usando
ora dovrei aggiungere un quinto rele comandato da un quinto tasto
una volta pigiato il quinto tasto il rele si deve eccitare per un secondo e poi tornare off
come posso fare?
grazie
Usa una variabile booleana, la attivi (=true) quando premi e memorizzi il valore millis() di quel momento.
Poi nella loop() se la variabile è vera fai un if che esegue un pezzo di codice che confronta la millis() con il valore precedentemente salvato e per differenza vedi quanto tempo è passato, un pò tipo l'esempio BlinkWithoutDelay
Allo scadere del tempo rimetti la variabile a false.
scusate la mia ignoranza ma non ci riesco
riesco solo ad ottenere ad ottenere che il rele (in questo caso il R5) mi si eccita poi si spegne e poi si eccita di nuovo :frowning:
qualche dritta?
Naturalmente provi a fare tutto in uno sketch complesso come quello che hai già, immagino.
Ma perchè non provi invece con uno sketch più semplice con solo il rele e quello che vuoi fare ?
In questo modo fai quello che devi con il rele e una volta capita la tecnica è più facile metterlo insieme all'altro.
Vedi lo sketch di esempio BlinkWithoutDelay e prova a leggere qui (ai link scritti da Guglielmo):
http://forum.arduino.cc/index.php?topic=358412.msg2471433#msg2471433
lo sketch che ho lo sto già utilizzando in una ciabatta per 220v in casa e non posso modificarla (mia mogli mi farebbe la pelle :slight_smile: )
vi prego datemi una mano
E' qualcosa tipo:
digitalWrite(5,HIGH);
digitalWrite(5,LOW);
ipotizzando che comandi il rele col pin 5 (1000 corrisponde a 1000ms -> 1sec)
if(strstr((char *)Ethernet::buffer + pos, "GET /R5") != 0) {
        L5 = !L5;
        Serial.println("a");
        Serial.println(L5);
        digitalWrite(6, L5);
        delay (5000);
        L5 = !L5;
        Serial.println("b");
        Serial.println(L5);
ho provato così
ma fa 3 scatti!!!!
a me ne servirebbe uno solo
aiuto
