DF player error with esp32 -Wroom
hello, im currently trying to set up my esp32 with a df player to play some music.
i have connected everthing but when im openening my serial monitor i get this error message. can someone explain me what does it mean ?
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
btw this is the arduino code im using.
#include <Arduino.h>
//#include <SoftwareSerial.h>
//#include "AltSoftSerial.h"
#include "DFRobotDFPlayerMini.h"
//SoftwareSerial mySoftwareSerial(16, 17); // RX, TX
//AltSoftSerial mySoftwareSerial(16, 17); // RX, TX
HardwareSerial mySoftwareSerial(1);
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
  mySoftwareSerial.begin(9600, SERIAL_8N1, 16, 17);  // speed, type, RX, TX
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
    Serial.println(myDFPlayer.readType(),HEX);
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.setTimeOut(500); //Set serial communictaion time out 500ms
  //----Set volume----
  myDFPlayer.volume(10);  //Set volume value (0~30).
  myDFPlayer.volumeUp(); //Volume Up
  myDFPlayer.volumeDown(); //Volume Down
  //----Set different EQ----
  myDFPlayer.EQ(DFPLAYER_EQ_NORMAL);
//  myDFPlayer.EQ(DFPLAYER_EQ_POP);
//  myDFPlayer.EQ(DFPLAYER_EQ_ROCK);
//  myDFPlayer.EQ(DFPLAYER_EQ_JAZZ);
//  myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);
//  myDFPlayer.EQ(DFPLAYER_EQ_BASS);
  //----Set device we use SD as default----
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_U_DISK);
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_AUX);
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SLEEP);
//  myDFPlayer.outputDevice(DFPLAYER_DEVICE_FLASH);
  //----Mp3 control----
//  myDFPlayer.sleep();     //sleep
//  myDFPlayer.reset();     //Reset the module
//  myDFPlayer.enableDAC();  //Enable On-chip DAC
//  myDFPlayer.disableDAC();  //Disable On-chip DAC
//  myDFPlayer.outputSetting(true, 15); //output setting, enable the output and set the gain to 15
  int delayms=100;
  //----Mp3 play----
  Serial.println(F("myDFPlayer.next()"));
  myDFPlayer.next();  //Play next mp3
  delay(delayms);
  Serial.println(F("myDFPlayer.previous()"));
  myDFPlayer.previous();  //Play previous mp3
  delay(delayms);
  Serial.println(F("myDFPlayer.play(1)"));
  myDFPlayer.play(1);  //Play the first mp3
  delay(delayms);
  Serial.println(F("myDFPlayer.loop(1)"));
  myDFPlayer.loop(1);  //Loop the first mp3
  delay(delayms);
  Serial.println(F("myDFPlayer.pause()"));
  myDFPlayer.pause();  //pause the mp3
  delay(delayms);
  Serial.println(F("myDFPlayer.start()"));
  myDFPlayer.start();  //start the mp3 from the pause
  delay(delayms);
  Serial.println(F("myDFPlayer.playFolder(15, 4)"));
  myDFPlayer.playFolder(15, 4);  //play specific mp3 in SD:/15/004.mp3; Folder Name(1~99); File Name(1~255)
  delay(delayms);
  Serial.println(F("myDFPlayer.enableLoopAll()"));
  myDFPlayer.enableLoopAll(); //loop all mp3 files.
  delay(delayms);
  Serial.println(F("myDFPlayer.disableLoopAll()"));
  myDFPlayer.disableLoopAll(); //stop loop all mp3 files.
  delay(delayms);
  Serial.println(F("myDFPlayer.playMp3Folder(4)"));
  myDFPlayer.playMp3Folder(4); //play specific mp3 in SD:/MP3/0004.mp3; File Name(0~65535)
  delay(delayms);
  Serial.println(F("myDFPlayer.advertise(3)"));
  myDFPlayer.advertise(3); //advertise specific mp3 in SD:/ADVERT/0003.mp3; File Name(0~65535)
  delay(delayms);
  Serial.println(F("myDFPlayer.stopAdvertise()"));
  myDFPlayer.stopAdvertise(); //stop advertise
  delay(delayms);
  Serial.println(F("myDFPlayer.playLargeFolder(2,999)"));
  myDFPlayer.playLargeFolder(2, 999); //play specific mp3 in SD:/02/004.mp3; Folder Name(1~10); File Name(1~1000)
  delay(delayms);
  Serial.println(F("myDFPlayer.loopFolder(5)"));
  myDFPlayer.loopFolder(5); //loop all mp3 files in folder SD:/05.
  delay(delayms);
  Serial.println(F("myDFPlayer.randomAll()"));
  myDFPlayer.randomAll(); //Random play all the mp3.
  delay(delayms);
  Serial.println(F("myDFPlayer.enableLoop()"));
  myDFPlayer.enableLoop(); //enable loop.
  delay(delayms);
  Serial.println(F("myDFPlayer.disableLoop()"));
  myDFPlayer.disableLoop(); //disable loop.
  delay(delayms);
  //----Read imformation----
  Serial.println(F("readState--------------------"));
  Serial.println(myDFPlayer.readState()); //read mp3 state
  Serial.println(F("readVolume--------------------"));
  Serial.println(myDFPlayer.readVolume()); //read current volume
  //Serial.println(F("readEQ--------------------"));
  //Serial.println(myDFPlayer.readEQ()); //read EQ setting
  Serial.println(F("readFileCounts--------------------"));
  Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
  Serial.println(F("readCurrentFileNumber--------------------"));
  Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
  Serial.println(F("readFileCountsInFolder--------------------"));
  Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read fill counts in folder SD:/03
  Serial.println(F("--------------------"));
  // static unsigned long timer = millis();
 if (Serial.available()) {
    String inData = "";
    inData = Serial.readStringUntil('\n');
    if (inData.startsWith("n")) {
      Serial.println(F("next--------------------"));
      myDFPlayer.next();
    } else if (inData.startsWith("p")) {
      Serial.println(F("previous--------------------"));
    } else if (inData.startsWith("+")) {
      Serial.println(F("up--------------------"));
    } else if (inData.startsWith("-")) {
      Serial.println(F("down--------------------"));
    } else if (inData.startsWith("*")) {
      Serial.println(F("pause--------------------"));
      myDFPlayer.pause();
    } else if (inData.startsWith(">")) {
      Serial.println(F("start--------------------"));
      myDFPlayer.start();
 if (myDFPlayer.available()) {
  if (myDFPlayer.readType()==DFPlayerPlayFinished) {
    Serial.println(myDFPlayer.read());
     myDFPlayer.next();  //Play next mp3 every 3 second.
 // if (myDFPlayer.available()) {
 //   printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
Its not an error message.
Looks like the normal power on reset message of an ESP32.
this never happened before.
i did some research before posting here and people with kinda similar message sad they had to flush the board. not sure what to do.
so shall i just ignore it or is there a way to fix it ?
