Hi, I´m trying to make a horn with three songs using the esp32 and the df player mini, but it doesn´t work and I don´t know why.
Here is the code and the electrical diagram. in the diagram we have to take into account that i can´t place a df player mini and i put a sd card reader; DI would be RX in the df player and Cs= TX. And CD and DO the speaker pins(horn).
Explanation of project:
four buttons (s1, s2, s3, s4), df player mini board and a speaker and do the following: when you press the first button the first song will be selected (N1) and a led will turn on on the df player mini and while pressing s4 button it will play the song. By pressing the s2 button the song N2 (and second led ON) will be selected and by pressing the s4 button the song will be played, by pressing the s3 button the song N3 (and third led ON) will be selected and by pressing the s4 button the song N3 will be played. This is the first three buttons (s1, s2, s3) are to select the song and the s4 button is to play the song.
The code:
#include <DFRobotDFPlayerMini.h>
#define SerialDebug Serial
// Use pins 26 and 27 to communicate with DFPlayer Mini
static const uint8_t PIN_MP3_TX = 26; // Connects to module's RX
static const uint8_t PIN_MP3_RX = 27; // Connects to module's TX
DFRobotDFPlayerMini player;
int pinPulsador1 = 4;
int pinPulsador2 = 19;
int pinPulsador3 = 21;
// Declaramos el pin al que estará conectado el led
int pinLed1 = 2;
int pinLed2 = 5;
int pinLed3 = 18;
bool reproduciendo1 = false;
bool reproduciendo2 = false;
bool reproduciendo3 = false;
void reproducirCancion(int numeroCancion) {
switch (numeroCancion) {
case 1:
player.play(1);
case 2:
player.play(2);
case 3:
player.play(3);
// Puedes agregar más casos según la cantidad de canciones que tengas
default:
// Determinamos que el pin del pulsador será para recibir
pinMode(pinPulsador1, INPUT);
// Determinamos que el pin del led será para salir
pinMode(pinLed1, OUTPUT);
pinMode(pinPulsador2, INPUT);
pinMode(pinLed2, OUTPUT);
pinMode(pinPulsador3, INPUT);
pinMode(pinLed3, OUTPUT);
// Inicia el puerto serial USB para depuración
SerialDebug.begin(115200);
// Inicia el puerto serial para DFPlayer Mini
Serial2.begin(9600, SERIAL_8N1, PIN_MP3_RX, PIN_MP3_TX);
// Inicia la comunicación con DFPlayer Mini
if (player.begin(Serial2)) {
SerialDebug.println("OK");
// Establece el volumen al máximo (0 a 30).
player.volume(20);
SerialDebug.println("Connecting to DFPlayer Mini failed!");
// Si la señal del pulsador 1 es activa, encendemos el LED 1 y reproducimos la canción 1
if (digitalRead(pinPulsador1) == HIGH) {
digitalWrite(pinLed1, HIGH);
if (!reproduciendo1) {
reproducirCancion(1);
reproduciendo1 = true;
digitalWrite(pinLed1, LOW);
// Si la señal del pulsador 2 es activa, encendemos el LED 2 y reproducimos la canción 2
if (digitalRead(pinPulsador2) == HIGH) {
digitalWrite(pinLed2, HIGH);
if (!reproduciendo2) {
reproducirCancion(2);
reproduciendo2 = true;
digitalWrite(pinLed2, LOW);
// Si la señal del pulsador 3 es activa, encendemos el LED 3 y reproducimos la canción 3
if (digitalRead(pinPulsador3) == HIGH) {
digitalWrite(pinLed3, HIGH);
if (!reproduciendo3) {
reproducirCancion(3);
reproduciendo3 = true;
digitalWrite(pinLed3, LOW);
delay(10);
electrical diagram:
