df player mini , arduino uno , Need help.
Hello guys, im working on a project with df player...And i have a problem that im trying to fix for last week but failing every time.
the problem is :
when i upload my code to the arduino it starts playing the sound from sd card and the light on df player turn on. but after like 0.5 - 2 seconds it shuts down and tries to play again and again and again
light go off, and everytime trying to play the sound from the beginning. It's not the code because i try around 7 different codes for the player none of them fixes the problem.
if you need any more information reply and ill do my best to give them to you.
i think there is no meaning in me posting my code because like I said, nothing is wrong with the code
BG, zazix
If it's not the code it's most likely a problem with how the player is powered or wired but you've given no information about those either.
Steve
thanks for fast reply, yes i forgot to include wiring diagram
The problem might also be in the code or even the contents of the SD card. Please post both in addition to the wiring schematic.
i dont have any of the code i deleted it all because none of them worked for me, i was just copy pasting the codes from tutorial i found on the web.
on my sd card i have a folder named mp3 and in that folder i have song names 0001.mp3
i will include pictures of my folder if you need to.
Take your best shot at the code (perhaps try this library) and then post it in tags.
