DF Player Mini sometimes not playing and giving weird -1 error
Hello, I'm trying to create a project where the rainbow rgb lights and mp3 music files start at the same time only when my sound sensor detects my clapping. It works most of the time, but 3 out 5 times I get a "-1" error in my Serial Monitor, the lights do turn on but there's no music playing. I have to clap again for it to move on to the next random song. I can't figure out what is causing this issue. Can anyone help me, please?
I use a Arduino nano for this project.
#include "Arduino.h"
#include "DFRobotDFPlayerMini.h"
#include <FastLED.h>
#include "SoftwareSerial.h"
#include <SPI.h>
#include <TimeLib.h>
#define NUM_LEDS  11
#define LED_PIN   2
CRGB leds[NUM_LEDS];
//has to be uint8_t so it starts at 0 after it reached 256
uint8_t hue = 0;
unsigned long lastIncrement = 0;
int SOUND_SENSOR = 3;
int RELAY = 2;
int clap = 0;
unsigned long detection_range_start = 0;
unsigned long detection_range = 0;
boolean ledsAreOn = false;
boolean clap_status = true; //true = plays a random mp3 file when arduino booted
int effectSpeed = 1;
int effectWide = 5;
/// mp3 player
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
//int files = 0;
//int durationA;
//int distance;
#define pinDFBusy 12
//unsigned long sonar_time = 0;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
long randNumber;
int result;
//int ultrasonic_flag = 0;
// char fileName[20];
// int fileToPlay;
  pinMode(SOUND_SENSOR, INPUT);
  pinMode(RELAY, OUTPUT);
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
  FastLED.setBrightness(50);
  // Serial.begin(115200);
  // randomSeed(analogRead(0));
  setupMP3();
  // triggerStart();
void setupMP3()
   // pinMode(13, OUTPUT);
   pinMode(pinDFBusy, INPUT);   // init Busy pin from DFPlayer (lo: file is playing / hi: no file playing)
   randomSeed(analogRead(0)); //random
   Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
   currentMillis = millis();
   // attachInterrupt(digitalPinToInterrupt(echoPinA), EchoPinA_ISR, CHANGE);  // Pin 2 interrupt on any change
   mySoftwareSerial.begin(9600);
    Serial.println(F("DFRobot DFPlayer Mini Demo"));
    Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
      myDFPlayer.setTimeOut(1000); //Set serial communication time out 500ms
    if (!myDFPlayer.begin(mySoftwareSerial)) {  //Use softwareSerial to communicate with mp3.
        Serial.println(F("Unable to begin:"));
        Serial.println(F("1.Please recheck the connection!"));
        Serial.println(F("2.Please insert the SD card!"));
        while(true);
    Serial.println(F("DFPlayer Mini online."));
 // myDFPlayer.setTimeOut(1000); //Set serial communication time out 500ms
  myDFPlayer.volume(10);  //Set volume value (0~30).
  myDFPlayer.EQ(DFPLAYER_EQ_BASS);
//  myDFPlayer.EQ(DFPLAYER_EQ_POP);
//  myDFPlayer.EQ(DFPLAYER_EQ_ROCK);
//  myDFPlayer.EQ(DFPLAYER_EQ_JAZZ);
//  myDFPlayer.EQ(DFPLAYER_EQ_CLASSIC);
//  myDFPlayer.EQ(DFPLAYER_EQ_BASS);
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
  //----Mp3 control----
//  myDFPlayer.sleep();     //sleep
//  myDFPlayer.reset();     //Reset the module
  myDFPlayer.enableDAC();  //Enable On-chip DAC
//  myDFPlayer.disableDAC();  //Disable On-chip DAC
//myDFPlayer.outputSetting(true, 15); //output setting, enable the output and set the gain to 15
  //----Read information----
  Serial.println(myDFPlayer.readState()); //read mp3 state
  Serial.println(myDFPlayer.readVolume()); //read current volume
  Serial.println(myDFPlayer.readEQ()); //read EQ setting
  Serial.println(myDFPlayer.readFileCounts()); //read all file counts in SD card
   //Serial.println(myDFPlayer.readCurrentFileNumber()); //read current play file number
  //Serial.println(myDFPlayer.readFileCountsInFolder(3)); //read file counts in folder SD:/03
boolean isPlaying = false;
void loop(){
  if (digitalRead(pinDFBusy) == LOW && isPlaying == false)
    // when busy is low, means is playing
    isPlaying = true;
  else if (digitalRead(pinDFBusy) == HIGH && isPlaying == true)
    // when busy is HIGH means it finished
    isPlaying = false;
    ledsAreOn = false;
    Serial.println(("-- SHOULD TURN OFF LEDS"));
  checkClap();
  playMusic();
  //if (tmrpcm.isPlaying() == 1)
    //You can change the pattern speed here
  if (millis() - lastIncrement > 20 && ledsAreOn)
    lastIncrement = millis();
    hue += effectSpeed;
    for (int i = 0; i < NUM_LEDS; ++i) {
      leds[i] = CHSV(hue + (i * effectWide), 255, 255);
    // ledsAreOn = true;
    FastLED.show();
     if (ledsAreOn == false)
       ledsAreOn = false;
          leds[i] = CRGB::Black;
       FastLED.show();
   if (myDFPlayer.available()) {
      printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void playMusic()
  if (clap_status == true)
      clap_status = false;
      randNumber = random(1,9);
      Serial.println(randNumber);
      myDFPlayer.playLargeFolder(1, randNumber); //play specific mp3 in SD:/01/0004.mp3; Folder Name(1~10); File Name(1~1000)
     // do
        //Serial.println("low");
        //ledsAreOn = false;
        //Serial.println(myDFPlayer.readState());
      ///while (digitalRead(pinDFBusy) == LOW);
void triggerStart()
  // todo choose effects
  // fileToPlay = random(1, 10);
  Serial.println(("-- SHOULD START MUSIC"));
  effectSpeed = random(-10, 10);
  effectWide  = random(0, 10);
  ledsAreOn = true;
  clap_status = true;
  // todo - choose song
  // todo - play song
  // sprintf(fileName, "%d.wav", fileToPlay);
  // tmrpcm.play(fileName);
//void EchoPinA_ISR() {
//    static unsigned long startTimeA;
//    if (digitalRead(2)) // Gone HIGH
//        startTimeA = micros();
//    else  // Gone LOW
//        LastPulseTimeA = micros() - startTimeA;
void checkClap()
  int status_sensor = digitalRead(SOUND_SENSOR);
  // todo add check for is playing
 if (status_sensor == 0 && digitalRead(pinDFBusy) == HIGH)
 // if (status_sensor == 0)
    Serial.println(("-- MIC ON"));
    if (clap == 0)
      Serial.println(("-- CLAP was 0 ++"));
      detection_range_start = detection_range = millis();
      clap++;
    else if (clap > 0 && millis() - detection_range >= 50)
      Serial.println(("-- clap++ because another clap in range"));
      clap++;
  if (millis() - detection_range_start >= 400)
    if (clap == 2)
      triggerStart();
    clap = 0;
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerUSBInserted:
      Serial.println("USB Inserted!");
    case DFPlayerUSBRemoved:
      Serial.println("USB Removed!");
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
This is what it shows in serial monitor:
-- MIC ON
1
-1
Time Out!
