Connecting UNO with a DF Player applying OneWireKeypad Library
With this finely working code below :
#include "OnewireKeypad.h" // OneWireKeypad Library
char KEYS[] = // Define keys' values of Keypad
'1', '2', '3', 'A',
'4', '5', '6', 'B',
'7', '8', '9', 'C',
'*', '0', '#', 'D'
/* Define Library :
OnewireKeypad <Print, #of buttons>
Keypad(Serial, Char values, #Rows, #Cols, Arduino Pin, Row_resistor, Columns_resistor) */
OnewireKeypad <Print, 16 > Keypad(Serial, KEYS, 4, 4, A0, 4700, 1000);
int ledpin = 2;
#include <DFPlayerMini_Fast.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial1(3, 1); // RX, TX
DFPlayerMini_Fast player1;
void setup ()
pinMode(ledpin, OUTPUT);
mySerial1.begin(9600);
if(player1.begin(mySerial1, false))
player1.volume(12);
player1.play(11);
Keypad.SetHoldTime(50); // Key held time in ms
Keypad.SetDebounceTime(25); // Key Debounce time in ms
if ((Keypad.Key_State() == 3)) // not pressed = 0, pressed = 1, released = 2, held = 3
char keypress = Keypad.Getkey(); // put value of key pressed in variable 'keypress'
Serial.print("Keypad Key: ");
Serial.println(keypress); // Display value on Serial Monitor
// while ((Keypad.Key_State())) {} // Stay here while Key is held down
if(keypress=='1')
player1.loop(14);
if(keypress=='2')
player1.loop(15);
if(keypress=='A')
player1.stop();
I am facing 2 small problems
There is a very very small delay between the trigger and sound play when a key on keypad is pressed.
It is very small but can effect many of the project programs so want to remove it completely -
While keep pressing the key or say doing press and hold function, the system continue triggers the assigned file from beginning depending on
Both the above points are dependent on SetHoldTime
If I am decreasing the value then the delay is getting shorten and shorten thus triggering the exact time of key press
But at the same moment it triggers file 2 3 times in the meantime
or
If there is any delay in releasing the key then it starts triggering the file continuously from beginning
I just want to remove this repeatedly triggering from the system
It is like :
If I press a key and hold it
It ll trigger the file once only
To trigger it again I ll have to release the key and press it back again. . .
Just exactly like
if(!digitalRead(Pin1))
player1.loop(10);
while(!digitalRead(Pin1));
Please Guide !!!!!
