DFPlayer mini, keep a LED on during playback
Hello. I'm working on a project that consists on:
A PIR sensor will activate DFplayer mini playback.
An LED should stay ON during playback, and off when no sound is being played.
The problem i'm facing is that the LED will stay ON for a second, playback continues but with the LED off.
I'm using DFPlayerMini_Fast.h library, and myDFPlayer.isPlaying() to detect playback, since I have been told, reading the busy pin status from the DFPlayer, says only if the sd card is being in use.
#include "SoftwareSerial.h"
#include "DFPlayerMini_Fast.h"
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFPlayerMini_Fast myDFPlayer;
void printDetail(uint8_t type, int value);
#define SENSORPIN 9
#define PAUSETIME 500
int randomInt;
#define LED 8     //  led a pin 8
  mySoftwareSerial.begin(9600);
  pinMode(SENSORPIN, INPUT);
  Serial.println(F("Initializing DFPlayer..."));
  //Use softwareSerial to communicate with MP3
  if (!myDFPlayer.begin(mySoftwareSerial)) {
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while(true);
  Serial.println(F("DFPlayer Mini online."));
  //Set volume value (From 0 to 30)
  myDFPlayer.volume(25);
void sensorActivated() {
// DFPlayerMini_Fast.h has a built-in function, "player.isPlaying()", that returns a boolean based on if the module is playing a song currently or not.
  int pirSensor = digitalRead(SENSORPIN);
 // if(pirSensor == HIGH && myDFPlayer.isPlaying()!=1)
    if(pirSensor == HIGH && myDFPlayer.isPlaying()==0)
    Serial.println("DFplayer status: ");
    Serial.println(myDFPlayer.isPlaying());
    Serial.println("Sensor Activated");
    Serial.println("DFPlayer Working...");
    randomInt = random(3, 8);
    Serial.println(randomInt);
    myDFPlayer.play(randomInt);
  digitalWrite(LED, HIGH);  // enciende led
if(myDFPlayer.isPlaying()==1)
    digitalWrite(LED, LOW); // apaga led
    Serial.println("Led OFF, player status: ");
    //Looks like player status 1 means playback is finished.
  return;
  sensorActivated();
  delay(PAUSETIME);
This is my serial monitor output.
DFPlayer Working...
Random track being played:
5
1
1
1
DFplayer status:
0
Sensor Activated
DFPlayer Working...
7
1
1
1
This codes says "if you are playing a song, turn the LED off" so that's what you get.
Will the project be expanded and be more complex functions later?
If not, I think no Arduino is needed for this. DFplayer can be triggered to play using one of its ADKEY pins. It also has a BUSY pin which could be used to drive a LED.
