got this code from member sonny22(thanks), to almost work. I build this for my slot car drag racing track, so when the car stages and blocking the sensor one, track one is playing. When car is ready to launch and passes over switch two, track two is playing. At this moment switch two starts to play track two when I first activate and then deactivate sensor two. Any suggestions how to approach a solution?
type or paste code here#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
#define ACTIVATED LOW
int buttonNext = 5;
int buttonPause = 4;
int buttonPrevious = 3;
bool switch1Pressed = false;
bool switch2Pressed = false;
SoftwareSerial mySoftwareSerial(10, 11); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
pinMode(buttonPause, INPUT);
digitalWrite(buttonPause, HIGH);
pinMode(buttonNext, INPUT);
digitalWrite(buttonNext, HIGH);
pinMode(buttonPrevious, INPUT);
digitalWrite(buttonPrevious, HIGH);
//checking if the dfplay is connected and ready to play
mySoftwareSerial.begin(9600);
Serial.println(F("DFRobot DFPlayer Mini Demo"));
Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
if (!myDFPlayer.begin(mySoftwareSerial)) { //Use softwareSerial to communicate with player.
Serial.println(F("Unable to begin:"));
Serial.println(F("1.Please recheck the connection!"));
Serial.println(F("2.Please insert the SD card!"));
while (true);
Serial.println(F("DFPlayer Mini online."));
// routine to play a specific song
void playTrackX(byte x) {
mySoftwareSerial.write((byte)0x7E);
mySoftwareSerial.write((byte)0xFF);
mySoftwareSerial.write((byte)0x06);
mySoftwareSerial.write((byte)0x03);
mySoftwareSerial.write((byte)0x00);
mySoftwareSerial.write((byte)x);
mySoftwareSerial.write((byte)0xEF);
// button Next is pressed play song 1
if (digitalRead(buttonNext) == ACTIVATED) {
// Om switch 1 precis blev nedtryckt, starta spår 1
if (!switch1Pressed) {
playTrackX(1);
// Uppdatera switch 1s status
switch1Pressed = true;
else {
// Om switch 1 släpps, sluta spåret 1
if (switch1Pressed) {
// Lägg till stoppfunktion för spår 1 här
// Exempel: myDFPlayer.stop();
// Återställ switch 1s status
// button Previous is pressed play song 2
if (digitalRead(buttonPrevious) == ACTIVATED) {
// Om switch 2 precis blev nedtryckt, starta spår 2
if (!switch2Pressed) {
playTrackX(2);
// Uppdatera switch 2s status
switch2Pressed = true;
else {
// Om switch 2 släpps, sluta spåret 2
if (switch2Pressed) {
// Lägg till stoppfunktion för spår 2 här
// Återställ switch 2s status
// button Pause is pressed play song 3
if (digitalRead(buttonPause) == ACTIVATED) {
playTrackX(3);
