dfplayer prank
I have been working on the code for a mp3 player prank. When finished it should play an mp3 file and then sleep for a random time, wake, play the file and then sleep a random time.
I have hit a brick wall, going round in circles and spending hours trying to get code to compile. At the moment on start up, I achieve sound... lots of times and then nothing. The random play doesn't seem to work.
I'm driving myself crazy, can anyone help?
#include <avr/sleep.h> //Needed for sleep_mode
#include <avr/wdt.h> //Needed to enable/disable watch dog timer
#include "Arduino.h"
#include "SoftwareSerial.h"
#include "DFRobotDFPlayerMini.h"
int count = 0;
int randTime = 0;
#define RX    3   // *** D3, Pin 2
#define TX    4   // *** D4, Pin 3
SoftwareSerial softSerial(RX, TX); // RX, TX
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
ISR(WDT_vect) {
  softSerial.begin(9600);
  if (!myDFPlayer.begin(softSerial)) {  //Use softwareSerial to communicate with mp3.
  myDFPlayer.outputDevice(DFPLAYER_DEVICE_SD);
  myDFPlayer.enableDAC();
  delay(200);
  myDFPlayer.volume(30);  //Set volume value. From 0 to 30
  myDFPlayer.play(1);  //Play the first mp3
  ADCSRA &= ~(1<<ADEN); //Disable ADC
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
 setup_watchdog(9); //8sec sleep
  sleep_mode();
  if(count >= randTime){
  randTime = random(255, 300);
  count = 0;
  delay(200);
      myDFPlayer.play(1);
 if (myDFPlayer.available()) {
    uint8_t type = myDFPlayer.readType();
    if (type == DFPlayerPlayFinished)
      myDFPlayer.disableDAC();
      myDFPlayer.sleep();
   }else{
    count++;
//Sets the watchdog timer to wake us up, but not reset
//0=16ms, 1=32ms, 2=64ms, 3=128ms, 4=250ms, 5=500ms
//6=1sec, 7=2sec, 8=4sec, 9=8sec
//From: http://interface.khm.de/index.php/lab/experiments/sleep_watchdog_battery/
void setup_watchdog(int timerPrescaler) {
  if (timerPrescaler > 9 ) timerPrescaler = 9; //Limit incoming amount to legal settings
  byte bb = timerPrescaler & 7;
  if (timerPrescaler > 7) bb |= (1<<5); //Set the special 5th bit if necessary
  //This order of commands is important and cannot be combined
  MCUSR &= ~(1<<WDRF); //Clear the watch dog reset
  WDTCR |= (1<<WDCE) | (1<<WDE); //Set WD_change enable, set WD enable
  WDTCR = bb; //Set new watchdog timeout value
  WDTCR |= _BV(WDIE); //Set the interrupt enable, this will keep unit from resetting after each int
Some suggestions for troubleshooting:
  1. check if sleep_enable() should appear somewhere in your code.
  2. strip out all the MP3 code and simply switch a led when the player should run.
    3 Look at https://www.gammon.com.au/forum/?id=11497 under "Waking from sleep with a timer".
  3. Use the code formatter in the IDE to correct the indentation.
