DFplayer
hello. can anyone say why i see this error:
mp3_set_serial was not declared in this scope
i've downloaded "DFPlayer-Mini-mp3-master" and placed in libraries folder. the code is bellow:
#include <SoftwareSerial.h>
#include <DFPlayer_Mini_Mp3.h>
void setup () {
  Serial.begin (9600);
  mp3_set_serial (Serial);      //set Serial for DFPlayer-mini mp3 module
  delay(1);                     // delay 1ms to set volume
  mp3_set_volume (15);          // value 0~30
void loop () {
  mp3_play (1);
  delay (6000);
  mp3_next ();
  delay (6000);
  mp3_prev ();
  delay (6000);
  mp3_play (4);
  delay (6000);
   mp3_play ();     //start play
 mp3_play (5);    //play "mp3/0005.mp3"
 mp3_next ();     //play next
 mp3_prev ();     //play previous
 mp3_set_volume (uint16_t volume);    //0~30
 mp3_set_EQ ();   //0~5
 mp3_pause ();
 mp3_stop ();
 void mp3_get_state ();   //send get state command
 void mp3_get_volume ();
 void mp3_get_u_sum ();
 void mp3_get_tf_sum ();
 void mp3_get_flash_sum ();
 void mp3_get_tf_current ();
 void mp3_get_u_current ();
 void mp3_get_flash_current ();
 void mp3_single_loop (boolean state);    //set single loop
 void mp3_DAC (boolean state);
 void mp3_random_play ();
The DFPlayer library isn't installed properly - you probably had a lot of other errors too, right?
A common mistake: you need to rename the library's folder from DFPlayer-Mini-mp3-master to just DFPlayer-Mini-mp3
yes i have more errors.
but rename the library wasn't effective :confused: again same error
oh solved! but now i have another error: Time out error
u use delay 600000ms
mp3_next ();
delay (600000);
have you ever use void
mp3_get_volume ();
commend ?
