Dfrobot Dissolved Oxygen meter reading 0 voltage
For context I did exactly as this tutorial said: https://www.youtube.com/watch?v=BHmkOjJRYwE&t=676s and I use an Arduino uno board
Serial monitor shows 0 voltage. Could it be that my board is broken? It overheated after I did a project just before I tested the meter so I thought maybe the voltage regulator is broken.
Additional info: code
#include <Arduino.h>
#define VREF    5000//VREF(mv)
#define ADC_RES 1024//ADC Resolution
uint32_t raw;
    raw=analogRead(A1);
    Serial.println("raw:\t"+String(raw)+"\tVoltage(mv)"+String(raw*VREF/ADC_RES));
how did you connect and power the board? a drawing of your circuit and link to the exact pH sensor model you have would help too
PS:
please, please never ever again post pictures of text... Not only they are not readable nor usable directly for copy&paste but they use up lots of storage and internet bandwidth which contributes to polluting the planet.
➜ do your part and do yourself a favour and please read How to get the best out of this forum
Here's the link.
did you do this ?
Yes, I did everything in the instructions
can you post a (in focus) close up of your wiring (the real device / connexion to the arduino) ?
can you make sure you connected to A1 and not A0 ?
did you plug the 5V and GND wires ?
Could be.
Can you download and run the blink example?
