DFRobot LCD keypad shield v1.1 problems
Hello a few weeks ago I purchased a generic LCD keypad shield from ebay and after receiving it and toying around with it I was not able get it to work. After a while I removed the LCD from the shield to connect directly to the LCD pins, and I got the same result where either the back light would turn on or not, every displaying anything therefore I figured the LCD was broken.
I decided I purchased a cheap shield, and decided to buy a more expensive with proper documentation. so I purchased this:
and upon plugging it in I go the same result as with the last shield. I then found this thread.
Warning to users of some vendors LCD keypad shields:
http://forum.arduino.cc/index.php?topic=96747.0
I ran the program and although my backlight lights up and pulses it is not displaying any characters.
I've tried various codes that claim to work with this shield and I am not getting any display, including
the liquidcrystal library. I am aware I must change the
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
to
LiquidCrystal lcd(8 ,9, 4, 5 ,6 ,7);
I appreciate the help, thank you.
Have you tried Example 1 from the wiki page?
Yes I actually have, and I've been toying around with it and for an unkown reason to me, I now can see characters
in the first row of, seems as if I have to restart my board a few times and then the characters show.
How after using the code from the wiki, instead of receiving the "Push the buttons" message I am receiving
"Pus' t'e buttgfs" and the second line is not displaying anything.
#0-7 are displayed properly while 8 and 9 show 0 and 1 instead.
Here is the code I used:
Thank you for the help.
  Mark Bramwell, July 2010
  This program will test the LCD panel and the buttons.When you push the button on the shield?
  the screen will show the corresponding one.
  Connection: Plug the LCD Keypad to the UNO(or other controllers)
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);           // select the pins used on the LCD panel
// define some values used by the panel and buttons
int lcd_key     = 0;
int adc_key_in  = 0;
#define btnRIGHT  0
#define btnUP     1
#define btnDOWN   2
#define btnLEFT   3
#define btnSELECT 4
#define btnNONE   5
int read_LCD_buttons(){               // read the buttons
    adc_key_in = analogRead(0);       // read the value from the sensor
    // my buttons when read are centered at these valies: 0, 144, 329, 504, 741
    // we add approx 50 to those values and check to see if we are close
    // We make this the 1st option for speed reasons since it will be the most likely result
    if (adc_key_in > 1000) return btnNONE;
    // For V1.1 us this threshold
    if (adc_key_in < 50)   return btnRIGHT;
    if (adc_key_in < 250)  return btnUP;
    if (adc_key_in < 450)  return btnDOWN;
    if (adc_key_in < 650)  return btnLEFT;
    if (adc_key_in < 850)  return btnSELECT;
   // For V1.0 comment the other threshold and use the one below:
     if (adc_key_in < 195)  return btnUP;
     if (adc_key_in < 380)  return btnDOWN;
     if (adc_key_in < 555)  return btnLEFT;
     if (adc_key_in < 790)  return btnSELECT;
    return btnNONE;                // when all others fail, return this.
void setup(){
   lcd.begin(16, 2);               // start the library
   lcd.setCursor(0,0);             // set the LCD cursor   position
   lcd.print("Push the buttons");  // print a simple message on the LCD
   analogWrite(10, 255);
void loop(){
   lcd.setCursor(9,1);             // move cursor to second line "1" and 9 spaces over
   lcd.print(millis()/1000);       // display seconds elapsed since power-up
   lcd.setCursor(0,1);             // move to the begining of the second line
   lcd_key = read_LCD_buttons();   // read the buttons
   switch (lcd_key){               // depending on which button was pushed, we perform an action
       case btnRIGHT:{             //  push button "RIGHT" and show the word on the screen
            lcd.print("RIGHT ");
       case btnLEFT:{
             lcd.print("LEFT   "); //  push button "LEFT" and show the word on the screen
       case btnUP:{
             lcd.print("UP    ");  //  push button "UP" and show the word on the screen
       case btnDOWN:{
             lcd.print("DOWN  ");  //  push button "DOWN" and show the word on the screen
       case btnSELECT:{
             lcd.print("SELECT");  //  push button "SELECT" and show the word on the screen
       case btnNONE:{
             lcd.print("NONE  ");  //  No action  will show "None" on the screen
Sounds like one of the data lines is dead. Check the board for a bad connection on 4, 5, 6, or 7
I had a similar problem and found that my power supply was not supplying enough power
Will do johnwasser, and once again I am not seeing any characters displayed, I think I am having issues with pin 7.
Edit: I have tried external power supplies and I am getting the same result...
Alrighty then, Pin 7 is dead :-(.....that's a bit sad
SuperCartman:
Pin 7 on the Arduino?
Did you look at the solder connections?
Perhaps it is just a bad solder joint.
Maybe re-heat the suspected connection(s) or maybe just
do all the LCD connections and see if it clears up.
--- bill
