I want to get this lcd but before I do I want to make sure it will work. So what i want to do is have a real time graph so im wondering if with there library you can do that?
thanks
ps i should mention i want to do this in spi mode.
I want to get this lcd but before I do I want to make sure it will work...
Which LCD?
Don
wow fail i forgot to post the link 3-wire Serial LCD Module (Arduino Compatible) - DFRobot
Well it's a graphical LCD and you want to plot a graph so it will probably be suitable. You will have to do some research and see if you can find a GLCD library that to is suitable for your application.
Don
will there library work for a graph?
I think I got the same display, but with out the SPI-module. I was not able to draw anything with the DFrobot-library. Only text...
With this library, I was able to do graph:
http://www.arduino.cc/playground/Code/LCD12864
If you want to use that, you will need get the SPI-stuff from the DFrobot-library, and paste them to that library. Here's my topic of that display:
http://arduino.cc/forum/index.php/topic,69847.0.html
I'm using a parallel-connection.
The DFrobot-library is better with text, so I'm trying to make a library wich could do text and draw lines.
