DFRodfrobot_INA219 not compiling under arduino 2.3.1 to 2.3.4
DFRobot_INA219 is not compiling under arduino 2.3.1 to 2.3.4 , but working with the older 1.8.19..
Does anyone have success using this sensor on newer Arduino versions ??
Thanks Michael
And the errors you're seeing would be...?
It would help if we could see your verbose error logs posted in code tags
Hi, @michaelvv
Welcome to the forum.
Thanks.. Tom.... :smiley: :+1: :coffee: :australia:
getVoltageCurrentpower example compiles in IDE 2.3.4 for a Nano.
I wonder if the OP is compiling for an ESP32 and has a 2.x core on their 1.8.19 installation and 3.x on their 2.x installation. With -Wall, there are a couple of warnings in the library, and didn't the 3.x ESP32 core start treating all warnings as errors? Just a thought...
Good point
It's why I mentioned the Nano. Just tested for an ESP32 Dev Module in IDE 2.3.4 and it compiles as well. Same warning. My warning lebel under file → preferences is set to All.
Not all by the looks of it; as far as I know it's not specific to version 3.x of the ESP32 board package, version 2.x has the same behaviour.
Ah well, it was just a stray thought.
Could have been correct :+1:
I'll try to make a better description why I cant compile it.
Arduino ver : 2.3.4
Dfrobot library : 1.0.0.
esp32 library : 3.1.1
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld: /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp.o:(.literal._Z41__static_initialization_and_destruction_0v+0x4): undefined reference to `_ZTV14DFRobot_INA219'
collect2: error: ld returned 1 exit status
exit status 1
Compilation error: exit status 1
Are you using another ina219 , library ???
Thanks michael.
How did you install the DFRobot_INA219 library? You didn't by chance simply find the header file and copy that someplace did you? I've seen that kind of error when people have done that.
IDE 2.3.4 on Windows
DFRobot_INA219 version 1.0.0
ESP32 board package version 3.1.1
Which operating system are you using (I can see it's not Windows)? Is your IDE 1.8.19 a portable installation?
In both IDEs please enable verbose output during compilation and please set the compiler warnings to All; both under file → preferences.
Compile in IDE 2.x and post the result here (please us code tags).
Repeat for IDE 1.x.
Not sure if I can help but it might point somebody else in the right direction.
I have both tried to install Dfrobot library 1.0.0 from github ( the .h .cpp files ) and tried to install it from the libarry manager...
In using Arduino 2.3.4 on Ubuntu 24.04.1 LTS. I'm using the arduino-ide_2.3.4_Linux_64bit.AppImage file..
Compiler output on 2.3.4
FQBN: esp32:esp32:esp32
Using board 'esp32' from platform in folder: /home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1
Using core 'esp32' from platform in folder: /home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1
/usr/bin/env bash -c "[ ! -f \"/home/michael/Arduino/getVoltageCurrentPower\"/partitions.csv ] || cp -f \"/home/michael/Arduino/getVoltageCurrentPower\"/partitions.csv \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/partitions.csv ] || [ ! -f \"/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32\"/partitions.csv ] || cp \"/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32\"/partitions.csv \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/partitions.csv ] || cp \"/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1\"/tools/partitions/default.csv \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/home/michael/Arduino/getVoltageCurrentPower\"/bootloader.bin ] && cp -f \"/home/michael/Arduino/getVoltageCurrentPower\"/bootloader.bin \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/getVoltageCurrentPower.ino.bootloader.bin || ( [ -f \"/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32\"/bootloader.bin ] && cp \"/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32\"/bootloader.bin \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/getVoltageCurrentPower.ino.bootloader.bin || \"/home/michael/.arduino15/packages/esp32/tools/esptool_py/4.9.dev3\"/esptool --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/getVoltageCurrentPower.ino.bootloader.bin \"/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32\"/bin/bootloader_qio_80m.elf )"
esptool.py v4.8.1
Creating esp32 image...
Merged 2 ELF sections
Successfully created esp32 image.
/usr/bin/env bash -c "[ ! -f \"/home/michael/Arduino/getVoltageCurrentPower\"/build_opt.h ] || cp -f \"/home/michael/Arduino/getVoltageCurrentPower\"/build_opt.h \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/build_opt.h"
/usr/bin/env bash -c "[ -f \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/build_opt.h ] || : > \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/build_opt.h"
/usr/bin/env bash -c ": > '/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts'"
/usr/bin/env bash -c "cp -f \"/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32\"/sdkconfig \"/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF\"/sdkconfig"
Detecting libraries used...
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -c @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/cpp_flags -w -Og -g3 -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="linux" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/defines -I/home/michael/Arduino/getVoltageCurrentPower -iprefix /home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/include/ @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/includes -I/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/qio_qspi/include -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/cores/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32 @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/build_opt.h @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire@3.1.1]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@3.1.1]
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -c @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/cpp_flags -w -Og -g3 -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="linux" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/defines -I/home/michael/Arduino/getVoltageCurrentPower -iprefix /home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/include/ @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/includes -I/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/qio_qspi/include -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/cores/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/libraries/Wire/src @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/build_opt.h @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp -o /dev/null
Alternatives for DFRobot_INA219.h: [DFRobot_INA219@1.0.0]
ResolveLibrary(DFRobot_INA219.h)
  -> candidates: [DFRobot_INA219@1.0.0]
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -c @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/cpp_flags -w -Og -g3 -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="linux" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/defines -I/home/michael/Arduino/getVoltageCurrentPower -iprefix /home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/include/ @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/includes -I/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/qio_qspi/include -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/cores/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/libraries/Wire/src -I/home/michael/Arduino/libraries/DFRobot_INA219 @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/build_opt.h @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp -o /dev/null
Using cached library dependencies for file: /home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/libraries/Wire/src/Wire.cpp
Using cached library dependencies for file: /home/michael/Arduino/libraries/DFRobot_INA219/DFRobot_INA219.cpp
Generating function prototypes...
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -c @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/cpp_flags -w -Og -g3 -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32_DEV" -DARDUINO_VARIANT="esp32" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="linux" -DARDUINO_FQBN="esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/defines -I/home/michael/Arduino/getVoltageCurrentPower -iprefix /home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/include/ @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/includes -I/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/qio_qspi/include -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/cores/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/libraries/Wire/src -I/home/michael/Arduino/libraries/DFRobot_INA219 @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/build_opt.h @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp -o /tmp/4050660581/sketch_merged.cpp
/home/michael/.arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/4050660581/sketch_merged.cpp
Compiling sketch...
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -MMD -c @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/cpp_flags -Wall -Wextra -Og -g3 -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"linux\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32:UploadSpeed=921600,CPUFreq=240,FlashFreq=80,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_CDC_ON_BOOT=0 @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/defines -I/home/michael/Arduino/getVoltageCurrentPower -iprefix /home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/include/ @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/includes -I/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/qio_qspi/include -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/cores/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/variants/esp32 -I/home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/libraries/Wire/src -I/home/michael/Arduino/libraries/DFRobot_INA219 @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/build_opt.h @/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp -o /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp.o
Compiling libraries...
Compiling library "Wire"
Using previously compiled file: /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/libraries/Wire/Wire.cpp.o
Compiling library "DFRobot_INA219"
Using previously compiled file: /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/libraries/DFRobot_INA219/DFRobot_INA219.cpp.o
Compiling core...
/usr/bin/env bash -c "echo -DARDUINO_CORE_BUILD > '/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/file_opts'"
Using precompiled core: /home/michael/.cache/arduino/cores/0220fcb1cffeedb3b79f550a790c76c0/core.a
Linking everything together...
/home/michael/.arduino15/packages/esp32/tools/esp-x32/2405/bin/xtensa-esp32-elf-g++ -Wl,--Map=/home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/getVoltageCurrentPower.ino.map -L/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/lib -L/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/ld -L/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/qio_qspi -Wl,--wrap=esp_panic_handler @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/ld_flags @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/ld_scripts -Wl,--start-group /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/sketch/getVoltageCurrentPower.ino.cpp.o /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/libraries/Wire/Wire.cpp.o /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/libraries/DFRobot_INA219/DFRobot_INA219.cpp.o /home/michael/.cache/arduino/cores/0220fcb1cffeedb3b79f550a790c76c0/core.a @/home/michael/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.3-cfea4f7c-v1/esp32/flags/ld_libs -Wl,--end-group -Wl,-EL -o /home/michael/.cache/arduino/sketches/1E553B9B57ED72A4F4FFB11E724468BF/getVoltageCurrentPower.ino.elf
Using library Wire at version 3.1.1 in folder: /home/michael/.arduino15/packages/esp32/hardware/esp32/3.1.1/libraries/Wire
Using library DFRobot_INA219 at version 1.0.0 in folder: /home/michael/Arduino/libraries/DFRobot_INA219
exit status 1
I did ask for a bit more. Same output but for IDE 1.8.19.
And is your IDE 1.8.19 a portable installation or a normal installation?
And I forgot to ask, which exact board are you compiling for?
I've just fired up my Ubuntu 24.04, installed the board package as well as the DFRobot_INA219 library. The getVoltageCurrentPower example compiles without issues in IDE 2.3.4 (AppImage) for the board ESP32 Dev Module.
This is for the arduino 1.8.19 , which works fine.
/home/michael/arduino/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/michael/arduino/arduino-1.8.19/hardware -hardware /root/.arduino15/packages -tools /home/michael/arduino/arduino-1.8.19/tools-builder -tools /home/michael/arduino/arduino-1.8.19/hardware/tools/avr -tools /root/.arduino15/packages -built-in-libraries /home/michael/arduino/arduino-1.8.19/libraries -libraries /root/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=no_ota,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path /tmp/arduino_build_932206 -warnings=default -build-cache /tmp/arduino_cache_562420 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool_py.path=/root/.arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=/root/.arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.mkspiffs.path=/root/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/root/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -verbose /root/Arduino/getVoltageCurrentPower/getVoltageCurrentPower.ino
/home/michael/arduino/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/michael/arduino/arduino-1.8.19/hardware -hardware /root/.arduino15/packages -tools /home/michael/arduino/arduino-1.8.19/tools-builder -tools /home/michael/arduino/arduino-1.8.19/hardware/tools/avr -tools /root/.arduino15/packages -built-in-libraries /home/michael/arduino/arduino-1.8.19/libraries -libraries /root/Arduino/libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=no_ota,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10819 -build-path /tmp/arduino_build_932206 -warnings=default -build-cache /tmp/arduino_cache_562420 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-80-g6c4433a-5.2.0.path=/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0 -prefs=runtime.tools.esptool_py.path=/root/.arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.esptool_py-2.6.1.path=/root/.arduino15/packages/esp32/tools/esptool_py/2.6.1 -prefs=runtime.tools.mkspiffs.path=/root/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=/root/.arduino15/packages/esp32/tools/mkspiffs/0.2.3 -verbose /root/Arduino/getVoltageCurrentPower/getVoltageCurrentPower.ino
Using board 'esp32' from platform in folder: /root/.arduino15/packages/esp32/hardware/esp32/1.0.4
Using core 'esp32' from platform in folder: /root/.arduino15/packages/esp32/hardware/esp32/1.0.4
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 /tmp/arduino_build_932206/sketch/getVoltageCurrentPower.ino.cpp -o /dev/null
Alternatives for Wire.h: [Wire@1.0.1]
  -> candidates: [Wire@1.0.1]
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /tmp/arduino_build_932206/sketch/getVoltageCurrentPower.ino.cpp -o /dev/null
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /tmp/arduino_build_932206/sketch/DFRobot_INA219.cpp -o /dev/null
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src/Wire.cpp -o /dev/null
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /tmp/arduino_build_932206/sketch/getVoltageCurrentPower.ino.cpp -o /tmp/arduino_build_932206/preproc/ctags_target_for_gcc_minus_e.cpp
/home/michael/arduino/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_932206/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /tmp/arduino_build_932206/sketch/DFRobot_INA219.cpp -o /tmp/arduino_build_932206/sketch/DFRobot_INA219.cpp.o
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /tmp/arduino_build_932206/sketch/getVoltageCurrentPower.ino.cpp -o /tmp/arduino_build_932206/sketch/getVoltageCurrentPower.ino.cpp.o
/root/Arduino/getVoltageCurrentPower/DFRobot_INA219.cpp: In member function 'void DFRobot_INA219::writeInaReg(uint8_t, uint16_t)':
/root/Arduino/getVoltageCurrentPower/DFRobot_INA219.cpp:182:33: warning: narrowing conversion of '(((int)value) >> 8)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
     uint8_t buffer[2] = {(value >> 8), value & 0xff};
/root/Arduino/getVoltageCurrentPower/DFRobot_INA219.cpp:182:46: warning: narrowing conversion of '(((int)value) & 255)' from 'int' to 'uint8_t {aka unsigned char}' inside { } [-Wnarrowing]
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-g++ -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/config -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_trace -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/app_update -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/asio -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bootloader_support -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/bt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/coap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/console -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/driver -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-tls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_adc_cal -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_event -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_client -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_http_server -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_https_ota -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp_ringbuf -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ethernet -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/expat -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fatfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freemodbus -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/freertos -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/heap -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/idf_test -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/jsmn -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/json -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/libsodium -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/log -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/lwip -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mbedtls -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mdns -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/micro-ecc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/mqtt -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/newlib -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nghttp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/nvs_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/openssl -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protobuf-c -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/protocomm -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/pthread -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/sdmmc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/smartconfig_ack -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/soc -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spi_flash -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/spiffs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcp_transport -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/tcpip_adapter -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/ulp -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/vfs -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wear_levelling -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wifi_provisioning -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/wpa_supplicant -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/xtensa-debug-module -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp32-camera -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/esp-face -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/include/fb_gfx -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/cores/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/variants/esp32 -I/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src /root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire/src/Wire.cpp -o /tmp/arduino_build_932206/libraries/Wire/Wire.cpp.o
Compiling core...
Using precompiled core: /tmp/arduino_cache_562420/core/core_8dc3df89be1ef9f1a764a5bb2668826d.a
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-gcc -nostdlib -L/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/lib -L/root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/sdk/ld -T esp32_out.ld -T esp32.common.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group /tmp/arduino_build_932206/sketch/DFRobot_INA219.cpp.o /tmp/arduino_build_932206/sketch/getVoltageCurrentPower.ino.cpp.o /tmp/arduino_build_932206/libraries/Wire/Wire.cpp.o /tmp/arduino_cache_562420/core/core_8dc3df89be1ef9f1a764a5bb2668826d.a -lgcc -lesp32 -lphy -lesp_http_client -lmbedtls -lrtc -lesp_http_server -lbtdm_app -lspiffs -lbootloader_support -lmdns -lnvs_flash -lfatfs -lpp -lnet80211 -ljsmn -lface_detection -llibsodium -lvfs -ldl_lib -llog -lfreertos -lcxx -lsmartconfig_ack -lxtensa-debug-module -lheap -ltcpip_adapter -lmqtt -lulp -lfd -lfb_gfx -lnghttp -lprotocomm -lsmartconfig -lm -lethernet -limage_util -lc_nano -lsoc -ltcp_transport -lc -lmicro-ecc -lface_recognition -ljson -lwpa_supplicant -lmesh -lesp_https_ota -lwpa2 -lexpat -llwip -lwear_levelling -lapp_update -ldriver -lbt -lespnow -lcoap -lasio -lnewlib -lconsole -lapp_trace -lesp32-camera -lhal -lprotobuf-c -lsdmmc -lcore -lpthread -lcoexist -lfreemodbus -lspi_flash -lesp-tls -lwpa -lwifi_provisioning -lwps -lesp_adc_cal -lesp_event -lopenssl -lesp_ringbuf -lfr -lstdc++ -Wl,--end-group -Wl,-EL -o /tmp/arduino_build_932206/getVoltageCurrentPower.ino.elf
python /root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/gen_esp32part.py -q /root/.arduino15/packages/esp32/hardware/esp32/1.0.4/tools/partitions/no_ota.csv /tmp/arduino_build_932206/getVoltageCurrentPower.ino.partitions.bin
python /root/.arduino15/packages/esp32/tools/esptool_py/2.6.1/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o /tmp/arduino_build_932206/getVoltageCurrentPower.ino.bin /tmp/arduino_build_932206/getVoltageCurrentPower.ino.elf
esptool.py v2.6
Using library Wire at version 1.0.1 in folder: /root/.arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/Wire
/root/.arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/1.22.0-80-g6c4433a-5.2.0/bin/xtensa-esp32-elf-size -A /tmp/arduino_build_932206/getVoltageCurrentPower.ino.elf
Sketch uses 223689 bytes (10%) of program storage space. Maximum is 2097152 bytes.
Global variables use 16124 bytes (4%) of dynamic memory, leaving 311556 bytes for local variables. Maximum is 327680 bytes.
Error downloading http://download.dfrobot.top/boards/package_DFRobot_index.json
I have 2 different ESP32 dev Module , both won't compile under 2.3.4 (AppImage)
Dfrobot library ver 1.0.0.
ESP32 ver 3.1.1 .
Ubuntu Ubuntu 24.04.1 LTS
I have seen that.
Nice one expressif.
Although not a problem really if expressif have provided a mechanism for stopping 'warnings' from being errors.
I managed to install the Dfrobot_INA219 in a virtualbox on a fresh ubuntu 24.4 ...
This is not working for me on my ubuntu 24.4 host system which is very strange ...
I have done exactly the same thing on the host , same version of everything , but
without any luck , so far...
Thank Michael.
