I have asked about my DFU problem in another thread
that thread seems to being ignored so I'll try again.
I could not get anywhere using the local IDE so thought I'd try the Cloud.
I could only get results on the Cloud if I went into bootloader mode.
Still getting the same DFU error.
/usr/local/bin/arduino-cli compile --fqbn arduino:mbed_giga:giga:split=100_0,target_core=cm7 --build-cache-path /tmp --output-dir /tmp/3109521301/build --build-path /tmp/arduino-build-490859082C29B3631CF2B3C828B088B2 /tmp/3109521301/barGraph
Sketch uses 120944 bytes (6%) of program storage space. Maximum is 1966080 bytes.
Global variables use 51840 bytes (9%) of dynamic memory, leaving 471784 bytes for local variables. Maximum is 523624 bytes.
Upload started
Programming with: Serial
Restarting in bootloader mode
Flashing with command:C:/Users/Ralph/.arduino-create/arduino/dfu-util/0.10.0-arduino1/dfu-util.exe --device 0x2341:0x0366 -D C:/Users/Ralph/AppData/Local/Temp/arduino-create-agent955768795/barGraph.bin -a0 --dfuse-address=0x08040000:leave
dfu-util 0.10-dev
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
Device ID 2341:0366
Device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 011a
Device returned transfer size 4096
DfuSe interface name: "Internal Flash 2MB "
Downloading element to address = 0x08040000, size = 123100
Erase [ ] 0% 0 bytes Erase [ ] 0% 0 bytes Erase [= ] 6% 8192 bytes Erase [== ] 9% 12288 bytes Erase [=== ]
13% 16384 bytes Erase [==== ] 16% 20480 bytes Erase [===== ] 23% 28672 bytes Erase [====== ]
26% 32768 bytes Erase [======= ] 29% 36864 bytes Erase [======== ] 33% 40960 bytes Erase [========= ]
36% 45056 bytes Erase [========== ] 43% 53248 bytes Erase [=========== ] 46% 57344 bytes Erase [============ ]
49% 61440 bytes Erase [============= ] 53% 65536 bytes Erase [============== ]
56% 69632 bytes Erase [=============== ] 63% 77824 bytes Erase [================ ]
66% 81920 bytes Erase [================= ] 69% 86016 bytes Erase [================== ]
73% 90112 bytes Erase [=================== ] 76% 94208 bytes Erase [==================== ]
83% 102400 bytes Erase [===================== ] 86% 106496 bytes Erase [====================== ]
89% 110592 bytes Erase [======================= ] 93% 114688 bytes Erase [======================== ]
96% 118784 bytes Erase [=========================] 100% 123100 bytes
Erase done.
Download [ ] 0% 0 bytes Download [= ] 6% 8192 bytes Download [== ] 9% 12288 bytes
Download [=== ] 13% 16384 bytes Download [==== ] 16% 20480 bytes Download [===== ] 23% 28672 bytes
Download [====== ] 26% 32768 bytes Download [======= ] 29% 36864 bytes Download [======== ] 33% 40960 bytes
Download [========= ] 36% 45056 bytes Download [========== ] 43% 53248 bytes Download [=========== ] 46% 57344 bytes
Download [============ ] 49% 61440 bytes Download [============= ] 53% 65536 bytes
Download [============== ] 56% 69632 bytes Download [=============== ] 63% 77824 bytes
Download [================ ] 66% 81920 bytes Download [================= ] 69% 86016 bytes
Download [================== ] 73% 90112 bytes Download [=================== ] 76% 94208 bytes
Download [==================== ] 83% 102400 bytes Download [===================== ] 86% 106496 bytes
Download [====================== ] 89% 110592 bytes Download [======================= ] 93% 114688 bytes
Download [======================== ] 96% 118784 bytes Download [======================== ] 99% 122880 bytes
Download [=========================] 100% 123100 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Warning: Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release
