DG408 wiring
Hello, I have DG408 (http://datasheets.maximintegrated.com/en/ds/DG408-DG409.pdf)
and it says in the following scheme that there is V+, V- and gnd, what does V- stands for?
thanks in advance,
srusha: Hello, I have DG408 (http://datasheets.maximintegrated.com/en/ds/DG408-DG409.pdf)
thanks in advance,
Just what it says negative supply voltage. That chip normally runs with 15v +- but supports a lot of different configurations. If you want to use it with positive voltage only connect v- to gnd as the datasheet says on page 6.
If you were running from dual supply, like +12V/-12V, V- would be -12V. If running from single +5 supply, V- goes to Gnd, per page 4.
Thats what I thought,
thanks for the quick reply.
