Hi im new toe the adruino ive have one for some time but haven’t really gotten into it till now
I have a DH 11 sensor and a Mega 2650 the sensor works with this code i would like to change the out put data from C to F
This is the code im using that works on my Mega
ive seen on other pages a code to insert but i have no idea where i would incert it here
thank you in advance for your help
#define dht11_pin 54 //Analog port 0 on Arduino Uno
//#define dht11_pin 54 //Analog port 0 on Arduino Mega2560
byte read_dht11_dat()
byte i = 0;
byte result=0;
for(i=0; i< 8; i++)
while (!digitalRead(dht11_pin));
delayMicroseconds(30);
if (digitalRead(dht11_pin) != 0 )
bitSet(result, 7-i);
while (digitalRead(dht11_pin));
return result;
pinMode(dht11_pin, OUTPUT);
digitalWrite(dht11_pin, HIGH);
Serial.println(“Ready”);
byte dht11_dat[5];
byte dht11_in;
byte i;// start condition
digitalWrite(dht11_pin, LOW);
delay(18);
delayMicroseconds(1);
pinMode(dht11_pin, INPUT);
delayMicroseconds(40);
if (digitalRead(dht11_pin))
Serial.println(“dht11 start condition 1 not met”); // wait for DHT response signal: LOW
return;
delayMicroseconds(80);
if (!digitalRead(dht11_pin))
Serial.println(“dht11 start condition 2 not met”); //wair for second response signal:HIGH
return;
delayMicroseconds(80);// now ready for data reception
for (i=0; i<5; i++)
{ dht11_dat = read_dht11_dat();} //recieved 40 bits data. Details are described in datasheet
- pinMode(dht11_pin, OUTPUT);*
- digitalWrite(dht11_pin, HIGH);*
- byte dht11_check_sum = dht11_dat[0]+dht11_dat[2];// check check_sum*
- if(dht11_dat[4]!= dht11_check_sum)*
- Serial.println(“DHT11 checksum error”);*
- Serial.print("Current humdity = ");*
- Serial.print(dht11_dat[0], DEC);*
- Serial.print("% ");*
- Serial.print("temperature = ");*
- Serial.print(dht11_dat[2], DEC);*
- Serial.println("C ");*
- delay(2000); //fresh time*
