DH22 & DS18B20
Hey, I'm doing a school project over the holidays using arduino but I've never don any programming or anything like that before. Anyway, I've got started and ive manged to setup a DH22 sensor aswell as a program for 2 temp sensors(DS18B20) which i can read at the same time. Now i want to combine the two programs so that I can read both humidity and both the temperatures.
I tried just copying and pasting the appropriate sections but it isnt working.
Here are the programs :
Temp Sensors
/* YourDuino Multiple DS18B20 Temperature Sensors on 1 wire
  Connections:
  DS18B20 Pinout (Left to Right, pins down, flat side toward you)
  - Left   = Ground
  - Center = Signal (Pin 2):  (with 3.3K to 4.7K resistor to +5 or 3.3 )
  - Right  = +5 or +3.3 V
   Questions: terry@yourduino.com
   V1.01  01/17/2013 ...based on examples from Rik Kretzinger
/*-----( Import needed libraries )-----*/
// Get 1-wire Library here: http://www.pjrc.com/teensy/td_libs_OneWire.html
#include <OneWire.h>
//Get DallasTemperature Library here:  http://milesburton.com/Main_Page?title=Dallas_Temperature_Control_Library
#include <DallasTemperature.h>
/*-----( Declare Constants and Pin Numbers )-----*/
#define ONE_WIRE_BUS_PIN 2
/*-----( Declare objects )-----*/
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS_PIN);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
/*-----( Declare Variables )-----*/
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress Probe01 = { 0x28, 0x92, 0xBD, 0x05, 0x06, 0x00, 0x00, 0x32 };
DeviceAddress Probe02 = { 0x28, 0x7E, 0x32, 0x06, 0x06, 0x00, 0x00, 0x4A };
DeviceAddress Probe03 = { 0x28, 0x4D, 0x8D, 0x40, 0x04, 0x00, 0x00, 0x78 };
void setup()   /****** SETUP: RUNS ONCE ******/
  // start serial port to show results
  Serial.print("Initializing Temperature Control Library Version ");
  Serial.println(DALLASTEMPLIBVERSION);
  // Initialize the Temperature measurement library
  sensors.begin();
  // set the resolution to 10 bit (Can be 9 to 12 bits .. lower is faster)
  sensors.setResolution(Probe01, 10);
  sensors.setResolution(Probe02, 10);
  sensors.setResolution(Probe03, 10);
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
  Serial.print("Number of Devices found on bus = ");
  Serial.println(sensors.getDeviceCount());
  Serial.print("Getting temperatures... ");
  // Command all devices on bus to read temperature
  sensors.requestTemperatures();
  Serial.print("Probe 01 temperature is:   ");
  printTemperature(Probe01);
  Serial.print("Probe 02 temperature is:   ");
  printTemperature(Probe02);
  Serial.print("Probe 03 temperature is:   ");
  printTemperature(Probe03);
}//--(end main loop )---
/*-----( Declare User-written Functions )-----*/
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
   if (tempC == -127.00)
   Serial.print("Error getting temperature  ");
   Serial.print("C: ");
   Serial.print(tempC);
   Serial.print(" F: ");
   Serial.print(DallasTemperature::toFahrenheit(tempC));
}// End printTemperature
//*********( THE END )***********
DH22
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
#include "DHT.h"
#define DHTPIN 5     // what pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT22   // DHT 22  (AM2302)
// Connect pin 1 (on the left) of the sensor to +5V
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 4 (on the right) of the sensor to GROUND
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
DHT dht(DHTPIN, DHTTYPE);
do the programs work separately?
Yeah, I've tried both and they work perfect
The second program you posted is only a partial sketch.
what you need to do is
  1. merge all global variables and check there is no conflict in name or resource (e.g. pin nr)
  2. merge the code in setup() 's but remove double lines like Serial.begin()
  3. merge the code in the loop()'s
after every step try to compile it.
Thanksfor the help so far. However now I get these errors - don't know how to fix them
DHTtester.ino: In function 'void loop()':
DHTtester:88: error: 'printTemperature' was not declared in this scope
DHTtester:106: error: a function-definition is not allowed here before '{' token
DHTtester:144: error: expected `}' at end of input
Here's the merged code
  Connections:
  - Left   = Ground
  sensors.begin();
Compiles fine for me under 1.0.4. Do you have other errors, possibly relating to missing libraries?
No, but i am using 1.0.5. Maybe i should try using 1.0.4
Hi humzy
The code compiles OK using 1.0.5 but I had to install the OneWire and DallasTemperature libraries.
However, your error messages mention lines 88, 106 and 144 of DHTtester.ino. Is that the name of your merged program? Reason for asking is that the code you posted only has 101 lines when pasted into the Arduino IDE.
Regards
Ray
Sorry, i dindn't copy the right code...
Here it is :
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
//#define DHTTYPE DHT11   // DHT 11
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
  Serial.println("DHTxx test!");
  dht.begin();
  sensors.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println("Failed to read from DHT sensor!");
    return;
 {delay(1000);
  Serial.println();}
  // Compute heat index
  // Must send in temp in Fahrenheit!
  float hi = dht.computeHeatIndex(f, h);
  Serial.print("Humidity: ");
  Serial.print(h);
  Serial.print(" %\t");
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print(" *C ");
  Serial.print(f);
  Serial.print(" *F\t");
  Serial.print("Heat index: ");
  Serial.print(hi);
  Serial.println(" *F");
and here are the error messages
Looks like this function is declared inside loop(). Try moving it outside.
