DH22 w/MKR1000 not working
I am really struggling getting the DH22 working with the MKR1000. It seems the serial port just stops or turns off as soon as the program gets to the loop. I used almost identical code with a UNO and it works. Only difference was pins used. Below is a copy of my code. What am I doing wrong?!
#include <dhtnew.h>
DHTNEW mySensor(5);   // ESP 16    UNO 5    MKR1010 5
float TempF;
uint32_t lastTime = 0;
  while(!Serial);        // MKR1010 needs this
  Serial.println(__FILE__);
  Serial.print("DHTNEW_LIB_VERSION: ");
  Serial.println(DHTNEW_LIB_VERSION);
   //mySensor.setDisableIRQ(false);
  if (millis() - lastTime > 2000)
    lastTime = millis();
    for (int pin = 6; pin < 15; pin++)
      DHTNEW sensor();
      sensor.read();
      TempF = sensor.getTemperature() * 1.8 + 32;
      Serial.print("Humidity");
      Serial.print("  ");
      Serial.print(sensor.getHumidity(), 1);
      Serial.print("Rh");
      Serial.print("  ");
      Serial.print("Temperature");
      Serial.print("  ");
      Serial.print(sensor.getTemperature(), 1);
      Serial.print("C");
      Serial.print("  ");
      Serial.print(TempF, 1);
      Serial.println("F");
  // Do other things here
Remove that line and try again.
