DHCP adress printer - Automatic update at power up
Hi everyone,
Is it possible to run this sketch (DHCPadressprinter) from the example list, in an other program, so it automaticly update my IP adress if it change?
Code to run every time my arduino power-up:
Serial.print("My IP address: ");
  for (byte thisByte = 0; thisByte < 4; thisByte++) {
    // print the value of each byte of the IP address:
    Serial.print(Ethernet.localIP()[thisByte], DEC);
    Serial.print(".");
Can someone write down a bit of code I should use to take the output of DHCPadress printer and place it in the IP adress section of this code?: (At about 1/3 of the code)
#include <SPI.h>
#include <Ethernet.h>
int number=0;
int time_1, time_2, time=0;
double up_time1, up_time2, up_time,upv;
// Adress variable
int four = 23, four_d = 23;
int three = 25, three_d = 25;
int two = 27,two_d = 27;
int one = 29, one_d = 29;
int adress, adress_2;
// END adress variable
//Sensors variable
float temp_bedroom=20.25;
float temp_kitchen=20.25;
float temp_washroom=20.25;
float temp_living=20.25;
//END sensors variable
// System status variable
int status_led = 22;
int sys_status=0;
// END System status variable
// Command over ethernet variable
boolean incoming = 0;
// END Command over ethernet variable
// Spam_block variable
int command;
int array[31];
int task=0;
int task_result =0;
// END Spam_block variable
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0x00, 0xAA, 0xBB, 0xCC, 0xDA, 0x02 };
IPAddress ip(208,92,17,141); //<<< ENTER YOUR IP ADDRESS HERE!!!             //////////TO REPLACE THIS IP ADRESSS!!!!/////////////////////////////////////////////////////////////
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(status_led, OUTPUT);
  pinMode(four, INPUT);
  pinMode(three, INPUT);
  pinMode(two, INPUT);
  pinMode(one, INPUT);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  up_time1 = millis();
  command_over_ethernet();
  led_status();
  delay(1);
void command_over_ethernet()
  // listen for incoming clients
  if (client) {
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        //reads URL string from $ to first blank space
        if(incoming && c == ' '){
          incoming = 0;
        if(c == '
For lenght reason, I didnt put all my functions
So, As the last function is called show_ip_adress, how to I update the IP at the beginnning of my code?
THANKS){
incoming = 1;
//Checks for the URL string $1 or $2
       if(incoming == 1){
         //Receive second code------------------------------------//
         if(c == ‘2’){
             //Serial.println(“ON”);
             //digitalWrite(2, LOW);
         //Send sensors status------------------------------------//
             if(c == ‘0’){
           //Fermer le néon des plante------------------------------//
             if(c == ‘1’){
if(c == ‘2’){
             if(c == ‘3’){
             if(c == ‘4’){
             if(c == ‘5’){
             if(c == ‘6’){
             if(c == ‘7’){
             if(c == ‘8’){
             if(c == ‘9’){
if (c == ‘\n’) {
         // you’re starting a new line
       else if (c != ‘\r’) {
         // you’ve gotten a character on the current line
         currentLineIsBlank = false;
   // give the web browser time to receive the data
   delay(1);
   // close the connection:
   client.stop();
void show_IP_ADRESS(){
 Serial.print(“My IP address: “);
   Serial.print(”.”);
THANKS
Look at what the "IP address printer" is doing. Strip out the stuff involved in printing the address from the stuff involved in getting the address to print. What is left in the get address to print part?
Ethernet.localIP()
You should be able to figure out where to make that call, and assign the results (byte by byte) to another variable.
Before you get too excited, though, think about WHERE the localIP() method gets the data that was being printed.
You TOLD it what its address is.
The only way your Arduino's address is going to change is if you don't have the router configured properly to always assign the same address to the Arduino or if you are using DHCP.
If you are using DHCP, you'd know about the address assigned to the Arduino, and there would be a lot of code dealing with getting an IP address.
Since there isn't, it's safe to assume that the problem is with your router, not with the Arduino.
