Below is the code I used
#include <SPI.h>
#include <WiFi.h>
//#include <EthernetENC.h>
#include <UIPEthernet.h>
const char* ssid = "hkiot";
const char* password = "10818117A*";
byte mac[] = { 0x1d, 0x0c, 0xd8, 0x0c, 0x55, 0xee };
char server[] = "www.google.com"; // name address for Google (using DNS)
#define CLIENT_ID "JEZIEL_78233"
IPAddress ip(192, 168, 3, 177);
IPAddress myDns(192, 168, 3, 1);
//setup_wifi();
SPI.begin(25, 32, 33, 27);
Ethernet.init(27);
Serial.println(Ethernet.hardwareStatus());
Serial.println(Ethernet.linkStatus());
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shißeld was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip, myDns);
Serial.print(" DHCP assigned IP ");
Serial.println(Ethernet.localIP());
This is the result of the above.
rst:0x1 (POWERON_RESET),boot:0x12 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
10
1
This circuit is a simplified version of only the Ethernet circuit in which enc28j60 is used in the circuit I made.
The code and circuit above worked normally once before.
I can't find the cause, so I'd like to ask for your help. thank you
