DHT-11 / weather station help
I'm hoping to get a little help. I have been able to get a weather station to work with an OpenweatherMap api using a small .94 oled and an esp8266-01. I then wanted to add a DHT 11 sensor to read indoor temperatures. I used two different projects from around the web and combined them. I have been able to get the screen to show the humidity and temp values but the values but they are 0. I forgot to mention I was using GPI01 (tx) for the data from the DHT 11.
Here is the code I have come up with so far, as I am still learning to code I am unable to see my error.
openweather_dht11.ino (12.7 KB)
Here are some of the additions I copied from another sketch to try and get the DHT sensor to work. I couldn't include the whole sketch as it was to many characters.
#include <ESPWiFi.h>
#include <ESPHTTPClient.h>
#include <JsonListener.h>
// time
#include <time.h>                       // time() ctime()
#include <sys/time.h>                   // struct timeval
#include <coredecls.h>                  // settimeofday_cb()
#include "SSD1306Wire.h"
#include "OLEDDisplayUi.h"
#include <Wire.h>
#include "OpenWeatherMapCurrent.h"
#include "OpenWeatherMapForecast.h"
#include "WeatherStationFonts.h"
#include "WeatherStationImages.h"
/* DHT22 */
#include <DHT.h>
const byte GPI01 = 1;
#define DHTPIN GPI01
#define DHTTYPE DHT11
int localHum = 0;
int localTemp = 0;
DHT dht(DHTPIN, DHTTYPE);
 * Begin Settings
// WIFI
const char* WIFI_SSID = "";
const char* WIFI_PWD = "";
#define TZ              -7       // (utc+) TZ in hours
#define DST_MN          0      // use 60mn for summer time in some countries
// Setup
const int UPDATE_INTERVAL_SECS = 20 * 60; // Update every 20 minutes
// Display Settings
const int I2C_DISPLAY_ADDRESS = 0x3c;
#if defined(ESP8266)
const byte GPI00 = 0;
const byte GPI02 = 2;
const int SDA_PIN = GPI00;
const int SDC_PIN = GPI02;
#else
const int SDA_PIN = 5; //GPI00;
const int SDC_PIN = 4; //GPI02;
#endif
// OpenWeatherMap Settings
// Sign up here to get an API key:
// Create OpenWeatherMap API key -
String OPEN_WEATHER_MAP_APP_ID = "";
Go to Find - OpenWeatherMap and search for a location. Go through the
result set and select the entry closest to the actual location you want to display
data for. It'll be a URL like Weather forecast - OpenWeatherMap. The number
at the end is what you assign to the constant below.
String OPEN_WEATHER_MAP_LOCATION_ID = "";
// Pick a language code from this list:
// Arabic - ar, Bulgarian - bg, Catalan - ca, Czech - cz, German - de, Greek - el,
// English - en, Persian (Farsi) - fa, Finnish - fi, French - fr, Galician - gl,
// Croatian - hr, Hungarian - hu, Italian - it, Japanese - ja, Korean - kr,
// Latvian - la, Lithuanian - lt, Macedonian - mk, Dutch - nl, Polish - pl,
// Portuguese - pt, Romanian - ro, Russian - ru, Swedish - se, Slovak - sk,
// Slovenian - sl, Spanish - es, Turkish - tr, Ukrainian - ua, Vietnamese - vi,
// Chinese Simplified - zh_cn, Chinese Traditional - zh_tw.
String OPEN_WEATHER_MAP_LANGUAGE = "en";
const uint8_t MAX_FORECASTS = 4;
const boolean IS_METRIC = true;
// Adjust according to your language
const String WDAY_NAMES[] = {"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"};
const String MONTH_NAMES[] = {"JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC"};
  • End Settings
    // Initialize the oled display for address 0x3c
    // sda-pin=14 and sdc-pin=12
    SSD1306Wire display(I2C_DISPLAY_ADDRESS, SDA_PIN, SDC_PIN);
    OLEDDisplayUi ui( &display );
OpenWeatherMapCurrentData currentWeather;
OpenWeatherMapCurrent currentWeatherClient;
OpenWeatherMapForecastData forecasts[MAX_FORECASTS];
OpenWeatherMapForecast forecastClient;
#define TZ_MN ((TZ)*60)
#define TZ_SEC ((TZ)*3600)
#define DST_SEC ((DST_MN)*60)
time_t now;
// flag changed in the ticker function every 10 minutes
bool readyForWeatherUpdate = false;
String lastUpdate = "--";
long timeSinceLastWUpdate = 0;
//declaring prototypes
void drawProgress(OLEDDisplay *display, int percentage, String label);
void updateData(OLEDDisplay *display);
void drawDateTime(OLEDDisplay display, OLEDDisplayUiState state, int16_t x, int16_t y);
void drawCurrentWeather(OLEDDisplay display, OLEDDisplayUiState state, int16_t x, int16_t y);
void drawForecast(OLEDDisplay display, OLEDDisplayUiState state, int16_t x, int16_t y);
void drawDHT(OLEDDisplay display, OLEDDisplayUiState state, int16_t x, int16_t y);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
void drawHeaderOverlay(OLEDDisplay display, OLEDDisplayUiState state);
void setReadyForWeatherUpdate();
// Add frames
// this array keeps function pointers to all frames
// frames are the single views that slide from right to left
FrameCallback frames[] = { drawDateTime,drawDHT,drawCurrentWeather, drawForecast };
int numberOfFrames = 4;
OverlayCallback overlays[] = { drawHeaderOverlay };
int numberOfOverlays = 1;
Wire.begin();
dht.begin();
// initialize dispaly
display.init();
display.clear();
display.display();
//display.flipScreenVertically();
// display.setFont(ArialMT_Plain_10);
//display.setTextAlignment(TEXT_ALIGN_CENTER);
// display.setContrast(255);
WiFi.begin(WIFI_SSID, WIFI_PWD);
int counter = 0;
Serial.print(".");
display.clear();
display.drawString(64, 10, "Connecting to WiFi");
display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
display.display();
counter++;
// Get time from network time service
configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
ui.setTargetFPS(30);
ui.setActiveSymbol(activeSymbole);
ui.setInactiveSymbol(inactiveSymbole);
// You can change this to
// TOP, LEFT, BOTTOM, RIGHT
ui.setIndicatorPosition(BOTTOM);
// Defines where the first frame is located in the bar.
ui.setIndicatorDirection(LEFT_RIGHT);
// You can change the transition that is used
// SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
ui.setFrameAnimation(SLIDE_LEFT);
ui.setFrames(frames, numberOfFrames);
ui.setOverlays(overlays, numberOfOverlays);
// Inital UI takes care of initalising the display too.
ui.init();
Serial.println("");
updateData(&display);
if (millis() - timeSinceLastWUpdate > (1000L*UPDATE_INTERVAL_SECS)) {
timeSinceLastWUpdate = millis();
if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {
int remainingTimeBudget = ui.update();
if (remainingTimeBudget > 0) {
void drawProgress(OLEDDisplay *display, int percentage, String label) {
  display->clear();
  display->setTextAlignment(TEXT_ALIGN_CENTER);
  display->setFont(ArialMT_Plain_10);
  display->drawString(64, 10, label);
  display->drawProgressBar(2, 28, 124, 10, percentage);
  display->display();
void updateData(OLEDDisplay *display) {
  drawProgress(display, 10, "Updating time...");
  drawProgress(display, 30, "Updating weather...");
  currentWeatherClient.setMetric(IS_METRIC);
  currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  currentWeatherClient.updateCurrentById(&currentWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID);
  drawProgress(display, 50, "Updating forecasts...");
  forecastClient.setMetric(IS_METRIC);
  forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  uint8_t allowedHours[] = {12};
  forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
  forecastClient.updateForecastsById(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID, MAX_FORECASTS);
  drawProgress(display, 100, "Done...");
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  now = time(nullptr);
  struct tm* timeInfo;
  timeInfo = localtime(&now);
  char buff[16];
  String date = WDAY_NAMES[timeInfo->tm_wday];
  sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon+1, timeInfo->tm_year + 1900);
  display->drawString(64 + x, 5 + y, String(buff));
  display->setFont(ArialMT_Plain_24);
  sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
  display->drawString(64 + x, 15 + y, String(buff));
  display->setTextAlignment(TEXT_ALIGN_LEFT);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  display->drawString(64 + x, 38 + y, currentWeather.description);
  String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
  display->drawString(50 + x, 5 + y, temp);
  display->setFont(Meteocons_Plain_36);
  display->drawString(28 + x, 0 + y, currentWeather.iconMeteoCon);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y) {
  drawForecastDetails(display, x, y, 0);
  drawForecastDetails(display, x + 44, y, 1);
  drawForecastDetails(display, x + 88, y, 2);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
  time_t observationTimestamp = forecasts[dayIndex].observationTime;
  timeInfo = localtime(&observationTimestamp);
  display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
  display->setFont(Meteocons_Plain_21);
  display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
  String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
  display->drawString(x + 20, y + 34, temp);
void drawDHT(OLEDDisplay *display, OLEDDisplayUiState* state, int16_t x, int16_t y)
  display->drawString(0 + x, 5 + y, "Hum");
  display->drawString(43 + x, y, "INDOOR");
  String hum = String(localHum) + "%";
  display->drawString(0 + x, 15 + y, hum);
  int humWidth = display->getStringWidth(hum);
  display->drawString(95 + x, 5 + y, "Temp");
  String temp = String(localTemp) + "°C";
  display->drawString(70 + x, 15 + y, temp);
  int tempWidth = display->getStringWidth(temp);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState* state) {
  char buff[14];
  sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
  display->setColor(WHITE);
  display->drawString(0, 54, String(buff));
  display->setTextAlignment(TEXT_ALIGN_RIGHT);
  display->drawString(128, 54, temp);
  display->drawHorizontalLine(0, 52, 128);
void setReadyForWeatherUpdate() {
  Serial.println("Setting readyForUpdate to true");
  readyForWeatherUpdate = true;
void getDHT()
  float tempIni = localTemp;
  float humIni = localHum;
  localTemp = dht.readTemperature();
  localHum = dht.readHumidity();
  if (isnan(localHum) || isnan(localTemp))   // Check if any reads failed and exit early (to try again).
    Serial.println("Failed to read from DHT sensor!");
    localTemp = tempIni;
    localHum = humIni;
    return;
ok thats the code , its a bit messy , thought i would split it up into sections so you don't have to download the file.
Hopefully its something simple I am missing, or ordering the code wrong.
I will try and rewrite the code from a wunderground example I found via instrucatables , that might be easier.
